I am looking forward for a method to sense in real time, using computer vision for a control application.
For this I am unsure of which is the right platform . I am well versed with MATLAB, but I am wondering if it will be able to do the image processing in real time or not.
If there are other platforms which are much quicker, you can please recommend me.
  • $\begingroup$ Welcome to Robotics qwerty123, but I'm afraid that shopping questions really aren't a good fit for a stack exchange site. We prefer practical, answerable questions based on actual problems that you face. Take a look at How to Ask and tour for more information on how stack exchange works, and the Robotics question checklist for details of how to write a good question. $\endgroup$
    – Chuck
    Jul 31 '17 at 13:07
  • $\begingroup$ If you are ever unsure about a Matlab toolbox, just call Mathworks and ask for a trial. I've used several trials in the past and, as I recall, the trial periods are pretty generous - I believe about 30 days. Speed is all relative to what you're trying to do but, in general, the fastest programs run in C++. $\endgroup$
    – Chuck
    Jul 31 '17 at 13:09
The branch of science that is binding vision and control is called visual servoying. You can find visp written in cpp or matlab implementations. Check also if visp is having a matlab bridge/api. If you have a professional robot (not a diy one ) i think ROS + visp will be a good start.
MATLAB is a very powerful platform for doing such applications. I recommend you using it. You can get your images using a USB camera, implement whatever functions to your captured images and then plot your results in a GUI charts or tabs.
Other software you can use is LabVIEW of NI, but you have to know how to use a function block diagram programming language.
I didn't work on matlab with vision,but if you want another choice you can always use c++/in visual studio with opencv libraries Or java in eclipse,but opencv function for c++ are easier and there are much more tutorials
