I am trying to the read the quadrature encoder on a ServoCity 624 RPM Premium Planetary Gear Motor w/Encoder with a SparkFun ESP32 Thing.
I am supposed to see 228 counts per revolution, but I see 230-232 instead.
Here is my Arduino code:
// Global variables modified by ISR
int state;
unsigned int count;
int error;
// ISR called on both edge of quadrature signals
void handleInterrupt()
// Shift old state into higher bits
state = ( state << 2 ) & 15;
// Get current state
if( digitalRead(34) ) state |= 2;
if( digitalRead(35) ) state |= 1;
// Check state change for forward or backward quadrature
// Flag any state change errors
switch( state )
case 1:
case 7:
case 14:
case 8:
count--;
break;
case 11:
case 13:
case 4:
case 2:
count++;
break;
default:
error++;
void setup()
pinMode(33, OUTPUT); // PWM
pinMode(32, OUTPUT); // DIR
pinMode(34, INPUT_PULLUP); // QB
pinMode(35, INPUT_PULLUP); // QA
attachInterrupt( digitalPinToInterrupt(34), handleInterrupt, CHANGE );
attachInterrupt( digitalPinToInterrupt(35), handleInterrupt, CHANGE );
Serial.begin(74880);
void loop()
int new_state;
int old_state;
// Start motor
digitalWrite(32, HIGH); // clockwise
digitalWrite(33, HIGH);
// 57*4-17 found by trial and error to make a complete revolution
for( int i = 0; i < (57*4-17); i++ )
// Busy wait for change
do
new_state = 0;
if( digitalRead(34) ) new_state |= 2;
if( digitalRead(35) ) new_state |= 1;
while( old_state == new_state );
old_state = new_state;
// Stop motor
digitalWrite(33, LOW);
delay( 1000 );
Serial.print( " state=" );
Serial.print( state );
Serial.print( " count=" );
Serial.print( count % 228 );
Serial.print( " error=" );
Serial.println( error );
- On my scope, quadrature signals are very clean
- I instrumented the code to look at interrupts and they appear to be in the right places and not too close together.
- I don't see mechanical slipping, and it would be obvious because over 100 revs, the count slips an entire revolution.
But the bottom line is: How can this be failing? If the CPU is missing transitions, I would get illegal transitions and errors. Noise would also cause errors. But I am not getting any errors at all (except a single error at startup).
