I have this servo motor (http://robokits.co.in/motors/high-torque-encoder-dc-servo-motor-60rpm-with-uart-i2c-ppm-drive?gclid=CLHf9_fCqNQCFVAeaAodhM0Ddg&). Generally, I have seen servo motor with three wires only but this servo motor have 6 wires. I want to rotate this using PPM signal and accordingly I made connection as described in motor manual. Arduino Code to rotate motor is:
// Include the Servo library
#include <Servo.h>
// Declare the Servo pin
int servoPin = 10;
// Create a servo object
Servo Servo1;
void setup() {
   // We need to attach the servo to the used pin number
   Servo1.attach(servoPin);
void loop(){
   // Make servo go to 0 degrees
   Servo1.write(0);
   delay(1000);
   // Make servo go to 90 degrees
   Servo1.write(90);
   delay(1000);
   // Make servo go to 180 degrees
   Servo1.write(180);
   delay(1000);
But what the motor does is it continuously turning. How to control motor position using PPM. Thanks.
Read this : http://www.robokits.co.in/documentation/RMCS220x_DCServo_Driver.pdf This is not exactly a servo. But it is a brushed DC motor coupled with an encoder and an inbuilt microcontroller to control the position from encoder feedback. The datasheet clearly says you can use PPM signal for speed control (RPM control) and not position control. Hence it does not work as a servo with PPM signal.
You need to use UART or I2C using Arduino to communicate with the motor, which is simple. You can check this tutorial on serial with Arduino : https://www.arduino.cc/en/reference/serial
Out of the six wires, only 4 will be used in case of controlling via UART:
  • V+ = 12V
  • UART RXD = Arduino TXD
  • UART TXD = Arduino RXD
  • GND = Arduino GND and power source ground
Now either you can program Arduino to send UART commands or use Arduino's Serial Terminal directly in the way the mentioned in Page 4. Make sure the baud rate is 9600 For a servo action you will mostly be using the commands :
  • GXXX
  • RXXX where XXX can be replaced with suitable encoder value. By using encoder specification from Page 3 : \begin{equation} XXX = \frac{Angle (in\hspace{5pt}degrees)}{0.2} \end{equation}
  • $\begingroup$ Thanks for reply. My major concern was here to rotate motor as easily as possible either through PPM or UART. Connections for UART was not problem for me as same given in user manual of motor, but I was facing problem in Arduino programming. But now I did programming and it working fine (robotics.stackexchange.com/questions/12583/…). Your answer help me to focus on UART and not on PPM. $\endgroup$ Jun 9, 2017 at 11:56
