I have a data point array. Which is recorded at 20Hz(0.05 second. It can be 30Hz, 40Hz, 50Hz. 20Hz is an example value)
little t
I want to interpolate this data to bigger frequency for example 1kHz(0.001 second) with cubic interpolation to get smooth data set. y(t) = at^3 + bt^2 + ct + d
little t
But I can't figure out how can I derive the function and implement with C.
Maybe you are looking for spline interpolation such as Cubic Hermite Splines, etc. However, it really depends on how you want you path looks.
  • If it is something like enter image description here
and you want something of third order (specifically, a velocity profile of third order), you can solve for a function $P_{01}(t) = at^3 + bt^2 + ct + d$ which satisfies, for example, $$ \begin{align} P_{01}(t_0) &= x_0\\ P_{01}(t_0) &= x_1\\ P_{01}'(t_0) &= 0\\ P_{01}'(t_1) &= 0\\ P_{01}''(t_0) &= 0\\ P_{01}''(t_1) &= 0, \end{align} $$ where $P'$ indicates the first time derivative of $P$, etc. You can substitute all the boundary conditions above to the function and solve for all the coefficients $a$, $b$, $c$, and $d$. You may want to have a look at polynomial interpolation and Vandermonde matrix. Note that if you change boundary conditions, you can also make the path looks smooth (i.e., not so zigzaggy).
  • If you just want a straight line between two consecutive points, you can even do $$ P_{01}(t) = x_0 + \left(\frac{x_1 - x_0}{t_1 - t_0}\right)(t - t_0). $$
You don't need to use higher-order polynomials.
  • If you, instead, want something like enter image description here
Spline interpolation might be more suitable.
| improve this answer | |
As I understand it, you want to fit a degree three polynomial to course data to be able to use the polynomial to interpolate between the course data points.
To be able to fit the coefficients ($a$, $b$, $c$, and $d$) of the degree three polynomial so that it goes through the original data points, you need exactly four data points, $(t_1,y_1), \cdots, (t_4,y_4)$. If you have more than four data points, the polynomial values will not necessarily go through the original data points.
Edit: Calculation of Polynomial Coefficients
For four sequential data points ($i,i+1,i+2,i+3$), the following equations must hold: \begin{eqnarray} at_i^3 +bt_i^2 +ct_i + d &=& y_i \\ at_{i+1}^3 +bt_{i+1}^2 +ct_{i+1} + d &=& y_{i+1} \\ at_{i+2}^3 +bt_{i+2}^2 +ct_{i+2} + d &=& y_{i+2} \\ at_{i+3}^3 +bt_{i+3}^2 +ct_{i+3} + d &=& y_{i+3} \end{eqnarray} This can be written as a matrix-vector equation $$ \left[\begin{array}{llll} t_i^3 & t_i^2 & t_i & 1 \\ t_{i+1}^3 & t_{i+1}^2 & t_{i+1} & 1 \\ t_{i+2}^3 & t_{i+2}^2 & t_{i+2} & 1 \\ t_{i+3}^3 & t_{i+3}^2 & t_{i+3} & 1 \end{array}\right] \left[\begin{array}{c} a \\ b \\ c \\ d \end{array}\right] = \left[\begin{array}{l} y_i \\ y_{i+1} \\ y_{i+2} \\ y_{i+3} \end{array}\right] $$ which can be solved for the vector of unknown coefficients ($a$, $b$, $c$, and $d$) using $$ \left[\begin{array}{c} a \\ b \\ c \\ d \end{array}\right] = \left[\begin{array}{llll} t_i^3 & t_i^2 & t_i & 1 \\ t_{i+1}^3 & t_{i+1}^2 & t_{i+1} & 1 \\ t_{i+2}^3 & t_{i+2}^2 & t_{i+2} & 1 \\ t_{i+3}^3 & t_{i+3}^2 & t_{i+3} & 1 \end{array}\right]^{-1} \left[\begin{array}{l} y_i \\ y_{i+1} \\ y_{i+2} \\ y_{i+3} \end{array}\right] $$ These coefficients can then be used to calculate the value of $y$ for a given $t$ where $t_i<t<t_{i+3}$: $$ y = at_3 + bt^2 +ct +d $$
I would recommend using a cubic spline interpolation method so that you will get a smooth interpolating curve that goes through all the original data points and that can handle more that four data points. See Numerical Recipes 3rd Edition: The Art of Scientific Computing by Press, et al. for very good C or C++ code to perform cubic spline interpolation.
