I tried getting pack sensors for packet group 100. What I noticed was the order of the packets did not match what's in the document. Anyone notice the same problem?
For example here is the output of packet group 6 & 101 - which should be the same at 100 but that's not the case. It would seem like the order of the packets are not the same in group 100.
Here is packet group 6:
2017/05/31 193538 PACKET GROUP 6 len:52
Bump & Wheel Drop: 0 - 1
Wall: 0 - 1
Cliff Left: 0 - 1
Cliff Front Left: 0 - 1
Cliff Front Right: 0 - 1
Cliff Right: 0 - 1
Virtual Wall: 0 - 1
Wheel Overcurrent: 0 - 1
Dirt Detect: 0 - 1
Unused 1: 0 - 1
Omni IR Code: 161 - 1
Buttons: 0 - 1
Distance: 0 - 2
Angle: 0 - 2
Charging: 0 - 1
Voltage: 15140 - 2
Current: -211 - 2
Temperature: 25 - 1
Battery Charge: 2234 - 2
Battery Capacity: 2696 - 2
Wall Signal: 0 - 2
Cliff Left Signal: 2938 - 2
Cliff Front Left Signal: 2047 - 2
Cliff Front Right Signal: 1399 - 2
Cliff Right Signal: 2232 - 2
Unused 2: 0 - 1
Unused 3: 0 - 2
Charging Source: 0 - 1
OI Mode: 1 - 1
Song Number: 0 - 1
Song Playing: 0 - 1
Num Stream Packets: 0 - 1
Req. Velocity: 0 - 2
Req. Radius: 0 - 2
Req. Right Velocity: 0 - 2
Req. Left Velocity: 0 - 2
Here is packet group 101:
2017/05/31 193859 PACKET GROUP 101 len:28
Left Encoder: 10 - 2
Right Encoder: 6 - 2
Bumper: 0 - 1
Bumper Left Signal: 11 - 2
Bumper Front Left Signal: 6 - 2
Bumper Center Left Signal: 8 - 2
Bumper Center Right Signal: 0 - 2
Bumper Front Right Signal: 11 - 2
Bumper Right Signal: 0 - 2
IR Code Left: 0 - 1
IR Code Right: 0 - 1
Left Motor Current: 0 - 2
Right Motor Current: 0 - 2
Main Brush Current: 0 - 2
Side Brush Current: 0 - 2
Stasis: 0 - 1
And here is packet group 100:
2017/05/31 193654 PACKET GROUP 100 len:80
Wall: 0 - 1
Cliff Left: 0 - 1
Cliff Right: 0 - 1
Virtual Wall: 0 - 1
Dirt Detect: 0 - 1
Unused 1: 0 - 1
Buttons: 0 - 1
Distance: 0 - 2
Angle: 0 - 2
Charging: 0 - 1
Voltage: 15140 - 2
Current: -219 - 2
Temperature: 25 - 1
Battery Charge: 2230 - 2
Wall Signal: 0 - 2
Cliff Left Signal: 2950 - 2
Cliff Front Left Signal: 2198 - 2
Cliff Front Right Signal: 0 - 2
Cliff Right Signal: 3072 - 2
Unused 2: 0 - 1
Unused 3: 0 - 2
OI Mode: 0 - 1
Song Number: 0 - 1
Song Playing: 0 - 1
Req. Radius: 0 - 2
Left Encoder: 8 - 2
Right Encoder: 4 - 2
Bumper: 0 - 1
Bumper Center Left Signal: 9 - 2
Bumper Front Right Signal: 0 - 2
IR Code Left: 0 - 1
Stasis: 0 - 1
