Hey all I would like to know what type of coupler I would need for this type of servo?
The specs are:
I'm guessing that the 25T means it has 25 teeth in the part that holds the adapters?
So I would guess I would need something like this?
But I also would like to know what size those are called for my servo. I've seen them advertised as 5mm to 8mm. 6mm to 8mm, etc etc so I don't know if those are going to work? Some also just have a smooth round hole without the teeth and I'm not sure if that's something I could use as well?
