A quite simple math is involved in this task, but you need to be aware of the pinhole camera model as well as of the homographic projection.
The pinhole camera model gives you the 3D position $(x,y,z)$ of a point in the space whose projection in the image plane corresponds to the $(u,v)$ pixel at a distance $\lambda$ from the image plane (considered infinite):
\left( \begin{array}{c} x \\ y \\ z \\ 1 \end{array} \right) = \Pi^\dagger \cdot \left( \begin{array}{c} \lambda \cdot u \\ \lambda \cdot v \\ \lambda \end{array} \right),
where $\Pi^\dagger$ is the pseudoinverse of the matrix $\Pi \in \mathbb{R}^{3 \times 4}$ that incorporates both the intrinsic parameters of your camera (i.e. the focal length, the pixel ratio and the position of the principal point) and the extrinsic parameters accounting for the position of the camera reference frame expressed in the world frame (i.e. a $\mathbb{R}^{4 \times 4}$ roto-translation matrix).
You have now to use the concept of homography, because you know that the object of interest lies on the plane $z=0$.
To do so, let's define the following quantities:
- $\mathbf{p}_0$, a point in the plane $z=0$; in particular, $\mathbf{p}_0=(0,0,0)$ is fine.
- $\mathbf{z}$, the normal to the plane $z=0$, that is $\mathbf{z}=(0,0,1)$.
- $\mathbf{c}$, the 3D position of the camera frame expressed in the world frame.
- $\mathbf{p}_1$, a 3D point that corresponds to the pixel $(u,v)$ at a distance $\lambda=1$.
Your final point $\mathbf{p}^*$ is therefore:
\mathbf{p}^*=\mathbf{c}+\frac{(\mathbf{p}_0-\mathbf{c}) \cdot \mathbf{z}}{(\mathbf{p}_1-\mathbf{c}) \cdot \mathbf{z}} (\mathbf{p}_1-\mathbf{c}).
That said, the strong assumption we're making here is that the object of interest is squashed on the plane $z=0$, that is it has a null height, which is not reasonable. To compensate for that, you could include such an information in the above process and replace the plane $z=0$ with $z=h$, where $h$ represents a suitable height.
