I have a .bag
which contains recorded messages on topics /topic1
and /topic2
. The messages have /world
as frame_id
, so both of the messages associated with these topics are stamped, i.e. they have a header.
The same .bag
file also contains recorded messages on the topic /tf
(of type tf2_msgs/TFMessage
). These transform messages have the frame_id
set to /world
and the child_frame_id
set to the local frames associated with the IMUs from which the messages are being sent over respectively topic /topic1
and /topic2
Now, I need the messages sent over the /topic1
and /topic2
to be converted to their corresponding local frame (i.e. the child frame or child_frame_id
) from the (fixed) frame /world
. Since both the /tf
messages and the messages of the topics /topic1
and /topic2
are stamped, I thought we could do this without much trouble, but I'm not sure since I'm very new to ROS.
I've looked around for various solutions, but I didn't find an exact solution for my problem, maybe because I didn't recognize it as such, given my limited knowledge of ROS, as I said.
I would appreciate a step by step description of the approach and, if you don't want to write a full solution with code (preferably in Python), at least point me to the similar examples. Please, do not suggest me to read the tutorials of /tf
, I've partially done it, and it didn't help much.
/topic1
and/topic2
to help with transforms. Knowing that messages are being published in the "/world
" frame and wanting to transform them to a different frame doesn't help if we don't know /what/ we're transforming. $\endgroup$ – Joshua Whitley Aug 30 '17 at 4:35
