I've tried to drill a number of holes in my iRobot.
I've missed one of them and I need the electronic scheme of iRobot Create 2 for trying to restore this input of the data cable.
Can you help me with that, please?
Photo of PCB
5
  • $\begingroup$ Welcome to Robotics, Raz. Have you tried contacting the manufacturer? I would doubt the schematics are freely available. I couldn't see where you drilled holes in the pictures. What exactly are you trying to do? $\endgroup$
    – Chuck
    May 3, 2017 at 18:13
  • $\begingroup$ I've tried to drill holes in the wrong place. I've drilled it exactly in the connector ( where I need to connect the data cable). Do you have the Email of the manufacture? Thanks $\endgroup$
    – Raz
    May 4, 2017 at 6:16
  • $\begingroup$ I bet if you read this page carefully, you'll find a way to contact the manufacturer: irobot.com/About-iRobot/STEM/Create-2/Projects.aspx $\endgroup$
    – Steve
    May 4, 2017 at 12:53
  • $\begingroup$ Welcome to Robotics Raz, but I'm afraid that questions which can only be answered by the technical support team for a specific manufacturer or supplier aren't a good fit for a stack exchange site. Practical, answerable questions based on actual problems that you face are always welcome here though, so if you edit your question to fit our community guidelines we can reopen it for you. Please take a look at How to Ask and tour for more information on how stack exchange works. $\endgroup$
    – Mark Booth
    May 10, 2017 at 13:04
  • $\begingroup$ I'm voting to close this question as off-topic because it is a technical support query. $\endgroup$
    – Mark Booth
The schematic for the main board on the iRobot Create 2 is currently not available. It is advised to remove the plastic top cover before drilling into the electronics below. (This is good practice for all electronics!) As suggested by another user, perhaps the manufacturer will be able to help you directly.
Please note that while I'm an iRobot employee, the postings on this site are my own and don't necessarily represent iRobot's positions, strategies, or opinions.
