-1
I foud tons of answer how glue with syringe, but I need to glue syriges together to be airtight and glue some silicon tube there too and cannot find a hint how to do it.
Does anybody know what glue does stick with syringe (eventually dissolve it a little)?
  • $\begingroup$ From your "robotic-arm" tag I'm guessing that you're looking to glue your robotic arm together. However, that doesn't seem to be of importance, so I think that this question belongs in an other StackExhange site like Engineering. $\endgroup$ May 1 '17 at 14:35
  • $\begingroup$ Ok, how to move it there? $\endgroup$
    – gilhad
    May 1 '17 at 14:46
I agree this question isn't really appropriate for this forum. That said, if you search "syringe plastic material," you'll find this Stack Exchange answer: https://chemistry.stackexchange.com/questions/65887/what-kind-of-materials-are-plastic-syringes-made-from, which suggests many syringes are made of polypropylene. If indeed that's what your syringes are made from, go get some glue appropriate for that material.
I used just hot soldering rod and it went well. I need to keep the heat low, but was able to solder the plastick together to be airtight. Just to be sure more I use the hot glue afteward to enforse the connections and make them more smooth. Not exactly nice looking, but works well enough.
