I have a problem with the Orocos IK solver, especially with the KDL::Rotation matrix input.
I try to call my KDL IK solver with a normal vector and a rotation. If I use the example values for the rotation everything went well. But as I tried to use my "own" orientation, the IK solver didn't find a solution.
 KDL::Vector vektor(0.457101 , -0.629513, -0.627317);
 KDL::Rotation rotation(1.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 1.0); //myValues
 KDL::Frame end_effector_pose(rotation, vektor);
 rc=kdl_solver.CartToJnt(origin,end_effector_pose,result);
As you can see it's a simple identity matrix -> no rotation -> in my opinion it should work. Anyway, if I try to call it with any other rotation matrix, it doesn't find a solution.
Just in case of
KDL::Rotation rotation(-0.0921467,0.939391, 0.330232, 0.925128, 0.203433,-0.32055,-0.368302,0.275969,-0.887803);
it terminates with a valid solution. These values are test values from my robot.
Do I have a wrong comprehension of the rotation matrix ?
Thank you very much for your time
Devel
EDITE:
With .msg communication it works. I have no idea why ? Does anyone know how the following lines construct the rotation matrix ??
geometry_msgs::PoseStamped pose_msg_in = pose_stamp;
tf::Stamped<tf::Pose> transform;
tf::Stamped<tf::Pose> > transform_root;
tf::poseStampedMsgToTF(pose_msg_in, transform);
tf_listener.transformPose(root_name, transform, transform_root);
KDL::Frame F_dest;  tf::transformTFToKDL(transform_root, F_dest);
int ik_valid = ik_solver_pos->CartToJnt(jnt_pos_in, F_dest, jnt_pos_out);
Or is the matrix related to something? I get the feeling that I miss a important information.
SOLVED: Sorry, for the delay. Shahbaz answer was totally right. I simply overestimated the capabilities of my robot. The position was not reachable. After using Moveit(visualisation), it became clear that the orientation is not possible for the robot at that position (x,y,z). THANKS
The vector and rotation together define the pose of the end-effector, which means its position and orientation. There are 6 degrees of freedom here (presumably), so you can think of the position as a point and the orientation as a direction (I'm avoiding "vector" to avoid confusion):
 |       P .-----> O
Where:
  • P is the position of the end-effector (defined with vector in your example)
  • O is the orientation of the end-effector (defined with rotation in your example)
So, what does the identity mean for the rotation matrix? It means the end-effector has the same orientation as a predefined original orientation. This could be different per robot. Let's say the original orientation has z upwards and x westwards.
What you are asking the solver is to solve IK for the end-effector at a given position and pointing upwards. As the function fails, it's clear that such a pose is unreachable by the robot.
Can't tell without knowing what your comprehension of the rotation matrix is! But the rotation matrix as I said defines the orientation based on some original orientation. The identity matrix is not a magic matrix where everything should work.
  • $\begingroup$ That's exactly what I thought about position and orientation -> So, that's clear. BTW, my robot arm has 7 DoF. In a previous approach I used the standard IK solver on my robots side. It needed a position and a quaternion, but KDL needs the position and the rotation matrix. The standard "orientation quaternion' for my robot is (1,0,0,0)[w,x,y,z] and the resulting rotation matrix is the identity matrix , isn't it ? So, in my opinion I should work. $\endgroup$
    – R.Devel
    Commented Apr 25, 2017 at 15:08
  • $\begingroup$ @R.Devel, have you tried other values for position? There's nothing wrong with the identity matrix, it may just be impossible with the given position. $\endgroup$
    – Shahbaz
    Commented Apr 25, 2017 at 21:45
  • $\begingroup$ No, it didn't work. But now it works...I have no idea why. I use messages to communicate with my IK solver (geometry_msgs/PoseStamped Message). As in my previous approach I send (x,y,z) and a Quaternion via .msg to my IKSolver. -> apparently it constructs the matrix and with that matrix it works. $\endgroup$
    – R.Devel
    Commented Apr 26, 2017 at 20:58
