I am using the ros_arduino_bridge to control a robot, by connecting the Arduino to a main pc with a usb cable. I was thinking of using the Arduino with main pc with a serial cable and then doing real time control of the Arduino by using the real time clock.
Is it possible to communicate with the Arduino in hard real time by using the real time clock and serial connections? I want to use Arduino board as a bridge between the main computer and the sensor and motors. And i want to control those sensors and motors in real time. All the high level processing tasks like computer vision and motion planning will be running in the main computer which then sends the commands to motors from the Arduino. So it is just acting like a bridge.
The reason I want hard real time is so that my robot can control its joints at very high and accurate speed so that the robot can do human level tasks like running, jumping, assembling some parts, balancing its body while moving(walking, running, jumping) at any speed (which requires the joints to be controlled at very high speed and accuracy) etc. I will be using gazebo simulator to test most of the tasks.
