I still think this is off-topic, but it seems I need more space than a comment to show (answer?) why that is so.
You are starting from some performance specifications and are looking to get to a set of features you need in your camera.
Here is a post from NI about stereo vision that gives a formula for depth resolution:
\Delta z = \frac{z^2}{fb}\Delta d \\
where $z$ is the depth of the object from the stereo system, $\Delta d$ is the depth resolution, $f$ is the focal length of the camera, $b$ is the baseline, and $d$ is the image disparity.
So, you want 1% depth resolution at 100 meters, or a depth resolution of 1 meter. A focal length of 8 millimeters, or 0.008 m, and a baseline of 0.5 m.
Rearranging the equation, it looks like you'll need a camera capable of registering a disparity of:
\Delta d = \Delta z \frac{fb}{z^2} \\
\Delta d = 1 \frac{(0.008)(0.5)}{100^2} \\
\Delta d = 4 x 10^-7 m \\
\Delta d = 0.4 \mu m \\
Assuming pixel accuracy (not sub-pixel accuracy), you'll want one pixel to be 0.4 $\mu$m or smaller, so the 0.4 $\mu$m disparity is registered as a one pixel shift between cameras.
Here's a list of sensor formats and sizes. I'm assuming these cameras all do "full HD", at a resolution of 1920x1080. Looking at the 2/3" format, the sensor width is 8.8 mm.
You need to register 0.4 $\mu$m, how does that compare to the 2/3" format? Well, at a width of 0.0088 m, with 1920 pixels across that width, the 2/3" format has a pixel width of $0.0088/1920 = 4.58\mu m$. So, off by a factor of 10. You need the pixel width to be about 11 times smaller.
So let's look at the 1/3" format - as in the iPhone 6. There the width is 4.8mm, so about half as wide, meaning you still need the pixels to be about 5-6 times smaller than the camera sensor in the iPhone.
This is also assuming you want to use every pixel in a full HD format - this will result in a high computation time. Most of the stereo vision projects I've seen have used cameras with lower resolutions or downsampled the image to a format like 640x480, but of course that means that the pixels are much (3x) larger.
You ask if "IP Cameras" are "proper," but IP cameras come in lots of styles.
Hopefully this will help you as a guide for your iterations. Plainly speaking, I don't think you'll ever find anything (that is reasonably affordable) that would do the depth resolution at the baseline you're talking about. I would imagine the baseline would be more on the range of 5-10 meters to get what you need. At 10 meters, fyi, the pixel size becomes 8 $\mu$m. At that point, most/all of the HD cameras should be able to do what you want, but again HD is computationally expensive because there are so many pixels to correlate.
This will be an iterative process. Work forward and backward and forward and backward until you get the design that meets your needs. You'll find you need to make tradeoffs along the way, and that's the core of engineering - finding the "optimal" balance of specifications. Cost, performance, size, cost, weight, interface, lead time, cost, cost, cost.
