5
I am currently thinking about making a robot that will autonomously drive around the place. The place I want this robot to drive in however contains quite a few glass walls. When mapping the area I would need to be able to see the glass. For this reason I am in need of a sensor that can see the glass, and not see through it. What kind of sensor would be the best for me? I need it to have a maximum range of about 2-10 meters and a minimum range of about 0.25 meters (preferably as small as possible). I was thinking about maybe using ultrasonic, but I was told that a laser-based sensor would probably be best. I could however only find industrial grade laser sensors that could see glass/transparent objects.
  • $\begingroup$ Thermal sensors, while expensive see glass as an opaque surface. You might get similar results using infrared lamps and detectors. $\endgroup$
    – Octopus
    Mar 8, 2017 at 6:34
  • $\begingroup$ @Octopus considering it will be on a moving robot in a regular environment, I doubt that using infrared lamps and detectors would work. Having to put up detectors all over the place is kind of out of the question. I will however have a look at thermal sensors. Thanks for the input! $\endgroup$
    – John Bow
    Mar 8, 2017 at 12:15
  • $\begingroup$ @Octopus I can't seem to find any information on Thermal Sensors that can tell me how far away the glass would be. I might have missed mentioning this in the post, but to avoid collisions with the glass, I ofcourse need to know the distance between the robot and the glass. $\endgroup$
    – John Bow
    Mar 8, 2017 at 12:31
  • $\begingroup$ Sorry, I didn't mean to imply that a thermal sensor can be used to measure range, it would be too complex and expensive anyhow, but that since thermal sensors see glass as opaque, then I imagine a basic IR proximity sensor probably would, too. $\endgroup$
    – Octopus
    Mar 8, 2017 at 17:56
3 Answers 3
I'm pretty sure that a very basic IR proximity sensor would do the trick. Glass is opaque to all but visible light. IR (as well as UV) will not penetrate the glass and you ought to be getting reliable distance measurements to the glass's surface.
7
  • $\begingroup$ Aha, this is what I was looking for. I'll have to look around for one with a decent range, since I need it to be able to measure to at least 2 meters from the sensor, but that will probably be doable just fine. Shame a LIDAR won't work. Since that uses laser instead of IR right? LIDAR seems very appropriate for mapping, just not when glass is involved. $\endgroup$
    – John Bow
    Mar 9, 2017 at 9:46
  • $\begingroup$ This was indeed the answer I was looking for, since I needed another option to compare my default option of an ultrasonic sensor with. I will however in the end use an ultrasonic sensor. This is due to the issues Infrared sensors can have with sunlight, and the fact that ultrasonic sensors generally have a longer range. Thanks again for your input! $\endgroup$
    – John Bow
    Mar 9, 2017 at 11:14
  • $\begingroup$ " Glass is opaque to all but visible light." this is very incorrect. google.com/search?q=glass+transmissivity $\endgroup$
    – Damien
    Sep 27, 2021 at 4:15
  • $\begingroup$ @Damien, within the scope of the question, my comment is valid. Is there something in a linked article that would make my comment misleading within this context? It wasn't an engineer's question. I mean, if you want to get technical, we could argue about what "opaque" means. $\endgroup$
    – Octopus
    Oct 12, 2021 at 21:57
  • $\begingroup$ IR will get through the glass as well as visible light (~400-750nm), up to at least 2500nm, which is way beyond any IR optical sensor, which makes your answer incorrect and misleading. There are other ways of detecting glass through light polarization, intensity, diffraction, and so forth. A generic sensor "might do the trick" but will yield an unreliable system inherent to the environment (lighting, background, etc..) if that sensor wasn't specifically designed for that purpose. $\endgroup$
    – Damien
    Oct 13, 2021 at 8:26
Unless you need very good resolution or a very tight detection pattern, I would go with an ultrasonic sensor. They can be very cheap and easily meet your detection range specs, for the very low end look at something like the HC-SR04, and for more serious applications Maxbotix offers a wide range of sensors.
  • $\begingroup$ Thankyou. This is very useful. Do you maybe have some examples of laser-based sensors too? So I can compare them? $\endgroup$
    – John Bow
    Mar 8, 2017 at 12:19
    $\begingroup$ Sure, the biggest one that comes to mind is the Lidar Lite V3 but it cannot detect surfaces that are reflective or clear, same for all LIDAR units that I know of in the lower than $1200 range. For the 0-10m range I think that Ultrasonic sensors are best, and for less than that IR proximity sensors will work well. $\endgroup$
    – Mark Omo
    Mar 8, 2017 at 20:48
I will recommend this Mini Lidar sensor that only costs $39.9
Also,you do need the ultrasonic distance sensor
Measurement range schematic diagram
