I have implemented a stable monocular slam tracking system, based on ORBSLAM2. I am trying to find a way to add real-world distance/scale to this.
At the same time, I am running a (less stable) stereo slam system.
What i would like to do is:
Using the correct scale of the stereo data, figure out the scale factor that is need to correct the mono to real-world scale, and multiply the output by this factor.
I do not want to adjust the slam algorithm, I need to take the two output streams (currently an Eigen::Vector3f for each stream) and find an algorithm that I can run for 30 seconds or so to find the scale difference, and therefore the factor that I need to multiply the mono by.
I am currently:
//Start system.
//Store both values as Eigen::Vector3f;
Eigen::Vector3f initialWrong;
Eigen::Vector3f initialTruth;
//sleep the thread for a few seconds, and move the sensors.
// get the distances
float stopWrong = CurrentWrong - initialWrong;
float stopTruth = CurrentTruth - initialTruth;
scaleFactor = stopTruth / stopWrong ;
This works, within a margin of error, but is very manual. I am looking for a more automatic / iterative way to do this that will minimize the error as much as possible.
How can I use a ground truth to scale monocular slam in real time?
Any thought or tips here would be greatly appreciated. Thanks.
  • $\begingroup$ I am not sure what you mean by 'is this a solved problem?'. If you're trying to initialize an environment with a known scale (from your stereo) and then keep track of your observations, do bundle adjustment etc. then perhaps something like PTAM (robots.ox.ac.uk/~gk/PTAM) will be of interest to you. The way PTAM initializes scale is by considering two viewpoints (which you probably wouldn't have to do as you have stereo slam already) $\endgroup$ Mar 3, 2017 at 4:54
  • $\begingroup$ Hi, thank you for your reply. I have edited my question for clarity. What i need is to find a way, using the two xyz output streams, to find the scale factor, and then multiply the mono position by this factor, bringing it in line with the ground truth. $\endgroup$
    – anti
    Mar 3, 2017 at 9:43
