9
I'm starting out with Gazebo (1.5) at the moment and am following a tutorial off the internet. In order to get Gazebo to find the model, the author advocates manually exporting the GAZEBO_MODEL_PATH environment variable via
export GAZEBO_MODEL_PATH=[...]/models:$GAZEBO_MODEL_PATH
But that will only work for the current terminal. So I wanted to change the environment variable permanently.
The Gazebo User Guide claims that GAZEBO_MODEL_PATH, along with all the other environment variables, is set by /usr/share/gazebo-1.5/setup.sh but my (virgin) Gazebo install doesn't list it:
export GAZEBO_MASTER_URI=http://localhost:11345
export GAZEBO_MODEL_DATABASE_URI=http://gazebosim.org/models
export GAZEBO_RESOURCE_PATH=/usr/share/gazebo-1.5:/usr/share/gazebo_models
export GAZEBO_PLUGIN_PATH=/usr/lib/gazebo-1.5/plugins
export LD_LIBRARY_PATH=/usr/lib/gazebo-1.5/plugins:${LD_LIBRARY_PATH}
export OGRE_RESOURCE_PATH=/usr/lib/i386-linux-gnu/OGRE-1.7.4
# This line is needed while we're relying on ROS's urdfdom library
export LD_LIBRARY_PATH=/opt/ros/fuerte/lib:${LD_LIBRARY_PATH}
But when I start Gazebo, GAZEBO_MODEL_PATH is already set to $HOME/.gazebo/models, so it must be set somewhere. I guess I could probably simply add GAZEBO_MODEL_PATH to the setup.sh script, but since it is set somewhere, I'd still like to know where and whether it is better practice to set it in there.
  • $\begingroup$ The answer by @Armin Meisterhirn should be marked as an answer IMO. Btw, Gazebo has its own QA forum answers.gazebosim.org $\endgroup$ – IsaacS Jan 13 '15 at 7:53
5
This is more of a Linux than a Gazebo problem. You can just add this line
to your ~/.bashrc file.
You asked two questions.
  1. Where does Gazebo set the default model path
  2. Where should I set the value
The second question is perfectly right answered by @Armin Meisterhirn. Best practice is to set the variable in the .bashrc file.
The first question, I asked myself as well when starting working with gazebo.
In case of the pure Gazebo (no roslaunch, no plugins) the answer is as simple as that:
In the source code. Gazebo always sets an additional path which is the default value.
Look here.
Line 84:
this->modelPaths.push_back(home + "/.gazebo/models");
As a result, you always have a default path, whatever you do (except you change the source code).
