I'm working on a robotics project and I've got this idea for a self learning algorithm. I'm looking for some feedback on this, and specifically on whether this is a more common way of doing things.
I simply want to store a lot of numerical log data of previous actions the robot took and the results it got. I then want to let it search through the DB multiple times per second so that the robot can make decisions based on that and thus learn from it's actions (like humans do).
So I constantly log a lot of data. One simple log record could be for example:
- speed: 5.43
- altitude: 35.23
- wind_speed: 6.19
- direction: 27
- current position: [12, -20]
- desired position: [18, -25]
- steering decision: 23
- success: 12
The desired_position
are coordinates on a 2 dimensional matrix and the success
is how close it came to the desired position within 10 seconds (so the lower the better).
I then have a certain situation for which I want to find a comparable experience in the database. So let's say my current situation is this:
- speed: 5.13
- altitude: 35.98
- wind_speed: 7.54
- direction: 24
- current position: [14, -22]
- desired_position: [17, -22]
As you can see it doesn't have a steering decision
or a success
yet, because it still has to make a steering decision and only after taking that action and seeing the result the success rate can be calculated.
So I want to search for the record "closest" to my current situation within certain boundaries, and which has the best (lowest) success rate. So for example, the boundaries could be that the direction
cannot be more than 10% difference, and the heading
cannot be more than 15% difference. So I first make a selection based on that. I'm left with A LOT of records. I then calculate for every field in every record the percentage difference, and accumulate those per record so that I get some sort of “closeness factor”. Once that's done I combine the closeness with the success, order by that number, and take the top record to base my decision on for the action to be taken. I take the steering decision of that record and randomly change it to something which is within a certain change percentage range. I do this because people also experiment, you try something new every time. And as the system becomes better at steering the robot (success factors get better) I also reduce the randomization change percentage. This is because as people get better, they also know that they are closer to the objective and they don't need to experiment as much any more.
So to steer my robot I will run the following process as often as possible (I will try to run it 20 times per second) and use this system to steer my robot.
So my questions are;
- Do you think that this can work?
- Is this kind of thing used more often?
- Does anybody know a database which would make it possible to query based on a dynamically calculated factor (the closeness factor)?
