I have Arduino and Matlab which has hardware support package for Arduino. I want to create SPWM signal (sinusoidal pulse width modulation) to be the output of the Arduino board. I could generate the signal required in Matlab using this code
function spwm = SinWave(frequency)
nsamples = 1250 * frequency;
t = linspace(0,1,nsamples);
sn = sin(2*pi*frequency*t);
st = sawtooth(2*pi*frequency*10*t);
spwm = abs(sn) > abs(st);
plot(t, sn);
hold on;
plot(t, st);
plot(t,spwm);
axis([0,1,-1.2,1.2]);
Now SPWM has the samples for the signal, I tried sending it on pin 13 using the following function
function writeSPWM(arduino, spwm)
for k=1:length(spwm)
writeDigitalPin(arduino, 'D13' ,spwm(k))
end
Then I used the following two lines in command window
a = arduino()
writeSPWM(a, SinWave(5))
I getting my signal shape with very low frequency(it is really much bigger) Is there a better way to achieve my goal? using Matlab is necessary but I have no problem if I have to combine coding throw Matlab and Arduino C.
