I have to determine speed and torque suitable for my combat robot. I've done some calculations and I need to know whether they're right or not (because they don't seem to be right).
Suppose I have 10kg robot, I want to push other 10kg robot to the arena walls. Let's first assume opposite robot is not opposing my push. Suppose I want it to move it with acceleration of 10cm/sec/sec (also lemme know if acceleration assumed is suitable for robowar or not). Then force required will be,
F = (total mass to be moved) * (acceleration) = (10+10)*(10e-2) = 2 N. Assume opposite robot is also pushing with me same force, in that case I will need another 2 N for opposing his push, Now taking into account frictional retardation, suppose I need another 2 N so total would be 6 N.
Assuming velocity = 10cm/sec, then Power required will be 6 * velocity = 6*10e-2 = 600mW. For 12V motor even with 20% efficiency it would cause current of 250mA only. Also output power = speed X torque.
Now I've heard that robowars usually require motor with high full load current otherwise they'll be damaged.
So it looks like I am somewhere wrong in my calculations. If so, lemme know where,am I wrong where I assumed that opposing robot will cause just 2 N, because generally they'd be fitted with more high torque motors. But is it the only thing which goes wrong in above calculations? If opposite bot had to just exert 2N on my bot, are calculations right?
PS: By side-shaft geared motors, it is meant that it is internally geared with horizontal shaft, right? Or "side-shaft" means something more?
