8
I'm trying to handle food grains like rice, wheat in an automated way (to cook simple dishes). For this I have to transfer grain from a larger container to a weighing scale. I know I can use solenoid valves for liquids but all solid handling valves seem to be too big (gate valves etc) and for larger applications. Is there any better way to do this ?
3 Answers 3
6
I suggest experimenting with a rotating cone feeder. If you make the rotation-speed and the cone's axis-angle adjustable, users could set it differently for different materials. The cone should be made easily removable, to allow easy cleaning and perhaps substitution of shorter, wider, or longer cones for different materials.
Rotating Cone Feeder
In the diagram, the axis of the cone is horizontal. The “natural angle of repose” referred to in the text is material-dependent and rotation-speed dependent. Up to some point, faster rotation delivers material faster. Some cone systems periodically reverse the direction of rotation. If the axis is horizontal, some given amount of material remains in the cone when it stops rotating, which might or might not matter in your process.
For other ideas, also see the Mixers page in the University of Michigan “Encyclopedia of Chemical Engineering Equipment”, and see the “Funnel Flow” section near the middle of the Hoppers page. As seen in the video there, the fairly coarse mixture in the hopper stops running a couple of times, until the mechanism is shaken back and forth.
A vibrating-screen device is shown in Vibrating Sieve Machine, Murat Model IV. A large rotating spiral brush is shown in AyrKing Breader/Blender/Sifter. An old Gyro-sifter machine appears in The Gyro-Sifter Machine! Odd.
  • $\begingroup$ Hey, the rotating cone link is broken now ... did anybody find a simple and cheap solution to this? I'm kind of new to this stuff. That picture looks like it has a stepper motor with a hollow body that drives a hollow cone ... not sure how to build that. $\endgroup$
    – fuzzyTew
    Oct 9, 2018 at 20:21
    $\begingroup$ @fuzzyTew, I haven't found a replacement for the rotating cone link, sorry. The picture is from the link in 2013 and seems schematic rather than detailed. It might be easier to use a belt, gear, or roller drive vs. finding a hollow-body stepper motor. $\endgroup$ Oct 20, 2018 at 17:59
There are all sorts of mechanisms for handling dry goods. If you want to do it on a small scale, look to industrial devices for inspiration, but consumer and retail devices for quick solutions. For example, there are quite a few cereal dispensers on on the market like this Zevro cereal dispenser:
Industrial systems often use augers to measure and move dry materials. I don't see why you couldn't build a small scale delivery device using a cheap auger bit rotating inside a pipe sized to fit the bit:
auger bit set
Dry goods are often measured by weight, so you might want to think about ways to weigh grains and similar materials. There are lots of cheap digital scales with a range of about 0-5kg and accurate down to a few grams. You could try to integrate one of those into your project directly, or cannibalize it for its load sensor, or even build your own load sensor. It'd be easy to put a small hopper on a scale to measure the material, use a simple gate to start and stop the flow of material into the hopper, and a solenoid to dump the hopper into a chute that delivers it for preparation.
  • $\begingroup$ Zevro approach to use a simple manually operated butterfly valve seems interesting. I could probably attach a servo at the turning knob. This still doesn't take care of getting out wheat flour though (because it tends to stick to walls). $\endgroup$
    – ivymike
    Apr 18, 2013 at 11:19
    $\begingroup$ @ivymike An auger-driven system might work better for flour. $\endgroup$
    – Caleb
    Apr 18, 2013 at 11:55
Mechanism could be similar to bubble-gum machine. Container fills up the cup (for which you know the mass of grains). With motor you need to rotate shaft with few cups from filling to spilling :) This would give you the resolution of mass that fills the cup. From there you can transfer that grains with conveyor to wherever you need.
  • $\begingroup$ I'm stuck at the part where we move the grains from container to weighing scale (which is just another container). I can't entirely depend on gravity because if I have to use wheat flour, it may not really drop that smoothly to the weighing scale. I'm thinking of tilting the container with a motor and then vibrate the container a bit to move the flour to the scale but not sure if there is any better way. $\endgroup$
    – ivymike
    Apr 2, 2013 at 12:53
    $\begingroup$ I'm not too familiar with food grains but I think you're on the right track with vibration. I know that all of the big factory systems use vibration to ensure smooth even flow of food items. $\endgroup$ Apr 2, 2013 at 14:03
