I am trying to find a joint like these for a robot I'm building. It is often called a swivel joint or a universal joint, but with a modified spider. I can't find one anywhere and would prefer not to make it. Searching for 'universal joint' returns the standard automotive type. Any help would be appreciated
$\begingroup$ I can't see any motion difference between them. So, what's the difference? $\endgroup$– mimipcMar 29, 2013 at 16:37
$\begingroup$ Why don't you modify your design to use a joint that's readily available in stores, then? $\endgroup$– fgbApr 4, 2013 at 0:38
Another name is pin and block - mcmaster carr is a go to place for many different fasteners, and mechanical doo-dads
