From Wikipedia:
The degree of freedom of a system can be viewed as the minimum number of coordinates required to specify a configuration
From Modern Robotics, definition 2.1:
The configuration of a robot is a complete specification of the position of every point of the robot. The minimum number n of real-valued coordinates needed to represent the configuration is the number of degrees of freedom (dof) of the robot
Those definitions feel intuitive, but however bijections can be made bewteen $\mathbb{R}$ and $\mathbb{R}^n$. Intuitively, we can interleave the decimals (plus some tricks). Thus, the "minimum number $n$ of real-valued coordinates" doesn't seem sufficient, since we could always reduce this number to 1, except if we add some extra condition about the topology of our coordinate system.
Am I missing something, or do we need to "fix" those definitions ?
