I am trying to read a PLY file and add it to the collision environment so that when motion planning, it is seen as a collision object.
My setup:
- Ubuntu 22.04
- ROS2 Humble
My code/workspace: https://github.com/wallelikesjinglebells/ws_pcl
Here's what I'm doing:
- My starting point is a PLY file, and I am successfully reading and publishing the file as a PointCloud2 message (package:
pcl_publisher
). Used command:ros2 run pcl_publisher pcl_publisher_node ~/ws_pcl/src/pcl_publisher/resource/TrialWall_PC.ply
- I am taking the PointCloud2 message and remapping
octomap_server_node
's subscription to/pcl
, my point cloud topic. Used command:ros2 run octomap_server octomap_server_node --ros-args -p frame_id:=world -r /cloud_in:=/pcl
- I am taking the data from
octomap_server_node
and publishing it to the planning scene (package:octomap_publisher
). Used command:ros2 run octomap_publisher octomap_publisher_node
- I am trying out my code on the demo panda robot from the MoveIt examples. Specifically, I am using the launch file from here, i.e.,
ros2 launch moveit2_tutorials move_group.launch.py
Up until this point, everything is working the way I want it to: The PLY file is correctly displayed in RViz as a collision object in my planning environment, and when I manually move the robot, the links that are colliding with the wall are marked red:
However, when I set a start (green) and goal (orange) state and hit 'Plan' in RViz, the robot moves through the collision object (the transparent robot body):
My trains of thought following this unwanted result:
- I first thought that the OctoMap was not updated frequently enough, but commands such as
ros2 topic echo /monitored_planning_scene
showed me that the topic does frequently receive the published data fromoctomap_publisher
. - I suspect my problem might have something to do with this message I get when launching the robot with
[move_group.moveit.moveit.ros.occupancy_map_monitor]: No 3D sensor plugin(s) defined for octomap updates
- Through this similar question I found this launch file (which includes octomap configurations when starting up
move_group_node
). I tried to implement something similar in mymove_group.launch.py
file but without success. Here is the code ofmove_group.launch.py
(unchanged from MoveIt's example, the comments are what I have unsuccessfully added trying to add the point cloud to OccupancyMapMonitor):
import os
from launch_ros.actions import Node
from launch.actions import ExecuteProcess
from ament_index_python.packages import get_package_share_directory
from moveit_configs_utils import MoveItConfigsBuilder
moveit_config = (
MoveItConfigsBuilder("moveit_resources_panda")
.robot_description(file_path="config/panda.urdf.xacro")
.trajectory_execution(file_path="config/gripper_moveit_controllers.yaml")
.to_moveit_configs()
# Start the actual move_group node/action server
run_move_group_node = Node(
package="moveit_ros_move_group",
executable="move_group",
output="screen",
parameters=[
moveit_config.to_dict(),
# 'octomap_resolution': 0.05,
# 'monitor_octomap': True,
# RViz
rviz_config_file = (
get_package_share_directory("moveit2_tutorials") + "/launch/move_group.rviz"
rviz_node = Node(
package="rviz2",
executable="rviz2",
name="rviz2",
output="log",
arguments=["-d", rviz_config_file],
parameters=[
moveit_config.robot_description,
moveit_config.robot_description_semantic,
moveit_config.robot_description_kinematics,
moveit_config.planning_pipelines,
moveit_config.joint_limits,
# Static TF
static_tf = Node(
package="tf2_ros",
executable="static_transform_publisher",
name="static_transform_publisher",
output="log",
arguments=["--frame-id", "world", "--child-frame-id", "panda_link0"],
# Publish TF
robot_state_publisher = Node(
package="robot_state_publisher",
executable="robot_state_publisher",
name="robot_state_publisher",
output="both",
parameters=[moveit_config.robot_description],
# ros2_control using FakeSystem as hardware
ros2_controllers_path = os.path.join(
get_package_share_directory("moveit_resources_panda_moveit_config"),
"config",
"ros2_controllers.yaml",
ros2_control_node = Node(
package="controller_manager",
executable="ros2_control_node",
parameters=[ros2_controllers_path],
remappings=[
("/controller_manager/robot_description", "/robot_description"),
output="both",
# Load controllers
load_controllers = []
for controller in [
"panda_arm_controller",
"panda_hand_controller",
"joint_state_broadcaster",
load_controllers += [
ExecuteProcess(
cmd=["ros2 run controller_manager spawner {}".format(controller)],
shell=True,
output="screen",
# # Octomap Monitor node
# octomap_monitor_node = Node(
# package="moveit_ros_perception",
# executable="occupancy_map_server",
# output="screen",
# parameters=[
# 'sensor_plugin': 'occupancy_map_monitor/PointCloudOctomapUpdater',
# 'max_range': 5.0,
# 'point_cloud_topic': '/pcl',
# 'frame_id': 'world',
return LaunchDescription(
rviz_node,
static_tf,
robot_state_publisher,
run_move_group_node,
ros2_control_node,
# octomap_monitor_node,
+ load_controllers
When trying to launch the robot with move_group.launch.py
with the now commented-out parts, I got this error, which I feel opens up a whole new set of issues for me to resolve:
Caught exception in launch (see debug for traceback): package 'moveit_ros_perception' found at '/home/user/ws_moveit/install/moveit_ros_perception', but libexec directory '/home/user/ws_moveit/install/moveit_ros_perception/lib/moveit_ros_perception' does not exist
If you have not figured it out by now, I am quite a newbie to everything ROS2-related, and I would be eternally grateful if someone could help me fix my problem.
