Is learning microcontroller programming useful for one who want to specialize in robotics I don't mean platforms like Arduino , Teensy , I mean mcu itself like Arm cortex etc.
  • $\begingroup$ Welcome to Robotics Jafar Abdi, but I'm afraid that Life Questions are off-topic. Questions about choosing how to spend your time (what book to read, which class to take, what robotics project to construct, what career to pursue, etc.) may be about difficult decisions, & they are often important, but they are too specific to your own situation & are unlikely to help future visitors to the site. They would be better off asked in Robotics Chat. We prefer practical, answerable questions based on actual problems that you face, see How to Ask & tour. $\endgroup$ – Mark Booth Jan 2 '17 at 12:52
I would say yes. At the lowest level in terms of robotic project development, you need to interface with hardware, e.g. sensors, motors, etc. So there's always demand in those area. As of if ARM uCs are worth learning, I would say yes also, since they are the most popular uCs on the market, you can find them on many platforms.
| improve this answer | |
Depending on which area of robotics you would like to specialize in, knowing what assembler is and how it should be used might indirectly help you to write more efficient code. It helps you less in industrial robotics, it helps you more in diy robotics. However, I doubt that you will ever write asm code, but I am sure that a solid understanding of bit and hex representation of variables will help you a lot. Assembler can give you this knowledge at a steep learning curve.
Since I think that general knowledge about assembler helps you, not specifically one complex mcu, I would recommend learning a simpler arhitecture like avr (arduino) at a low level (just to know how assembler works) It offers you a good insight into porgrammjng but you will most probably never write assembly code directly.
Furthermore, I would recommend knowing C/C++ well, since most microcontroller applications are written using these languages.
