Good morning, I am trying to control two different robots with ROS Noetic 20.04 (installed on Oracle VM), a mobile robot (MIR100) and a cobot (UR3 cb series), in order to do so i run their launch scripts: MIR script: roslaunch mir_driver mir.launch
UR3 script: roslaunch ur_robot_driver ur3_bringup.launch robot_ip:=192.x.x.x kinematics_config:=$(rospack find ur_calibration)/ur3_robot_calibration.yaml)
As soon as i run them both an error occurs: [WARN] Shutdown request received. [WARN] Reason given for shutdown: [[/robot_state_publisher] Reason: new node registered with same name].
So i guess i have to change the name of the node in one of the two files, but i don't know how to properly do it, because i am afraid to make a mess. I saw that in the mir.launch file, for example, the node is defined; i don't know if i can just change the name in that file to solve the problem. Thank you in advance!
