Rewriting this whole question as I've learned a lot more since I first tried to ask.
I'm building a tiny bot and looking to use two motorized wheels for movement, but only one motor. I'll have a 3rd wheel (caster) for balance.
My goal is to have the wheels move opposite to each other when the motor turns and each wheel reverse direction when the motor reverses direction.
The tricky part is I want the ratio to be uneven between the wheels. By this, I mean when one wheel rotates clockwise, it should rotate faster than the other wheel rotating counter-clockwise. This needs to hold true regardless of which wheel is rotating which way.
The end result should be that I could run the motor in one direction continuously to have my bot drive in a small circle. If I switch motor directions, it would drive in the same size circle the opposite direction. If I alternate motor directions frequently enough, the bot should move in a fairly straight line (or if I alternate the motor too infrequently, an S like pattern).
The closest I can envision so far (thanks to those that have responded here) is to use bevel/miter gears to have my wheels rotate opposite to each other and then to use two differently sized ratcheting mechanisms per wheel working in opposite directions. This would allow each ratcheting mechanism to trigger only in one direction and the RPM per direction would be related to the size of that direction's ratcheting mechanism.
Is this the best way to achieve my goal? Is there a name for this concept or is it so uncommon I'll have to build/fabricate it all myself? As far as a ratcheting mechanism, I believe I'd be looking to use a freewheel clutch or I'd need an oscillating lever carrying a driving pawl over top a ratchet gear. My biggest struggle in finding affordable parts is the ratcheting mechanism.
3 Answers 3
Are you talking about a bevel gear? Here's a video - the gold gear would be connected to the motor and the blue gears would be connected to your wheels.
Both wheels are always powered - one is powered in forward and the other is powered in reverse.
You're not clear on the purpose of this device, so I don't know if this fits your needs.
A differential allows the wheels to rotate at different speeds, but they generally still rotate in the same direction. You could use a brake band or something similar to lock an output axle and force all of the drive power to be delivered to the other wheel, but then one wheel is locked and not able to turn freely.
Hopefully this helps, but again I'm not clear on what you want to do. Generally it's best to provide your end application if you're looking for help on naming a particular mechanism.
9
  • $\begingroup$ +1 Just for the awesome videos. A bevel gear would indeed be the start of what I believe I'd be looking for. The concept would require both wheels to only spin in one direction though. When attempting to spin in the "wrong" direction, I'd want full power on the other wheel that's spinning the "right" direction. $\endgroup$ Dec 20, 2016 at 22:54
  • $\begingroup$ As I think about it, it'd actually be best if each wheel always rotated one direction at a slightly higher rpm rather than either wheel locking up or rotating freely. $\endgroup$ Dec 20, 2016 at 23:01
  • $\begingroup$ @MythicsWinter - Instead of saying "+1", you can use the up/down arrows to the left of the answer to actually give (or take) points to a user. I'm very curious as to what your end application is - can you share any details? $\endgroup$
    – Chuck
    Dec 21, 2016 at 4:14
  • $\begingroup$ I did use the up arrow, but I am new to robotics on stackexchange and it will not display up/down votes until I have more reputation (10 or 20 I think it is). I added an edit to the question giving more detail. The gist of it is I want to make swarm bots with 2 motorized wheels using only one motor. No reverse, but have left/right turning capabilities and alternate running the motor to go "forward". I'm just getting started with electronics/arduino, but I'd be pretty happy to just use the concept for an obstacle avoidance bot. $\endgroup$ Dec 21, 2016 at 12:48
    $\begingroup$ @MythicsWinter - If you're talking about making the gearbox from a 3d printer, I would highly, highly recommend you try to find a local Makerspace, library, university, etc. that would let you try a 3d print. The print quality of a reasonably affordable (<$1000) printer is not that great, requires lots of tuning, etc. Try one that's up and running and already tuned and see if that part works for you. You can use a service like Shapeways to get parts 3d printed on industrial-grade printers, but you're not going to get nearly the efficiency you need in a gearbox to make it feasible. $\endgroup$
    – Chuck
    Dec 21, 2016 at 15:48
A freewheel clutch attached to each wheel will do what you want.
When turned in one direction the clutch will transmit power to the wheel but in the opposite direction it will free spin.
This way when the motor is turned in one direction one wheel will turn and in the other direction the other wheel will turn in the same direction as the first.
The catch is you will have no ability to reverse.
  • $\begingroup$ Any idea how to go about finding a freewheel clutch for a super tiny wheel? =\ I'm talking axle of around 5mm. $\endgroup$ Dec 21, 2016 at 2:45
  • $\begingroup$ Another name for freewheeling clutches is sprag clutches (different mechanism, same effect) Dynatect's Polyclutch range is their smallest. They will go down to an axle of 5mm but the housing may or may not be small enough. link Otherwise, this guy built his own using Lego Technic link $\endgroup$
    – Michael
    Dec 22, 2016 at 4:04
Do you want the non-engaged wheel to be locked in place while the other wheel is rotating? If so, I cannot think of any transmission that will do this easily without getting rather complicated.
If you can accept the non-engaged wheel being free to rotate (as if in neutral), then you may be able to take advantage of a clever arrangement of simple mechanisms to do the job. The two that come to mind are both described at Carnegie-Mellon's Introduction to Mechanisms course. You could place a ratchet that engages in one direction to drive the ratchet wheel attached to one wheel's axle, and does not engage when it is rotated the other direction. Then do the reverse ratchet design for the other wheel. You could also use two opposite-direction engaging overdriven clutches to accomplish the same purpose.
Both of these implementations will have considerable backlash, and the non-driven wheel will be uncontrolled. It is not clear if that is acceptable to your application.
I do not know of any common term for such a device, but it sounds like fun to develop!
  • $\begingroup$ I would prefer the non-engaged wheel to still rotate, but in the opposite direction of the engaged wheel and around half the RPM of the engaged wheel. The ratchet concept sounds like a fairly reasonable alternative as well, I'm just having a hard time finding something I could simply purchase to fill this need (for super tiny wheels at a reasonable price). I'm quite the beginner in this area. $\endgroup$ Dec 21, 2016 at 2:49
  • $\begingroup$ A differential can be made to rotate, for example, "left wheel forward and right wheel reverse" when the motor spins in one direction, and the opposite when it spins in the other direction. However, the forward and reverse ratios (speeds) are the same. $\endgroup$
    – SteveO
    Dec 21, 2016 at 14:09
    $\begingroup$ The only option I can envision on my own then would be to use something to have the wheels rotate opposite to one another and two different sized ratcheting mechanisms like in your link, per wheel. One large one for driving the wheel forward and a small one for driving the wheel backward. I just wouldn't use the locking pawl for either. This is starting to sound doable now, if only I had the ability/skill/tools to craft it myself. $\endgroup$ Dec 21, 2016 at 14:30
