I'm trying to setup Nav2 for Humble but everytime I send a goal I get the following error:
[INFO] [1722361205.771845530] [controller_server]: Received a goal, begin computing control effort.
[WARN] [1722361205.771907547] [controller_server]: No goal checker was specified in parameter 'current_goal_checker'. Server will use only plugin loaded general_goal_checker . This warning will appear once.
Segmentation fault (core dumped)
Here is what my controller_server params look like, they are taken from nav2 Humble github.
controller_server:
ros__parameters:
use_sim_time: True
controller_frequency: 20.0
min_x_velocity_threshold: 0.001
min_y_velocity_threshold: 0.5
min_theta_velocity_threshold: 0.001
failure_tolerance: 0.3
progress_checker_plugin: "progress_checker"
goal_checker_plugins: ["general_goal_checker"]
controller_plugins: ["FollowPath"]
# Progress checker parameters
progress_checker:
plugin: "nav2_controller::SimpleProgressChecker"
required_movement_radius: 0.5
movement_time_allowance: 10.0
general_goal_checker:
stateful: True
plugin: "nav2_controller::SimpleGoalChecker"
xy_goal_tolerance: 0.25
yaw_goal_tolerance: 0.25
# DWB parameters
FollowPath:
plugin: "dwb_core::DWBLocalPlanner"
debug_trajectory_details: True
min_vel_x: 0.0
min_vel_y: 0.0
max_vel_x: 0.26
max_vel_y: 0.0
max_vel_theta: 1.0
min_speed_xy: 0.0
max_speed_xy: 0.26
min_speed_theta: 0.0
# Add high threshold velocity for turtlebot 3 issue.
# https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
acc_lim_x: 2.5
acc_lim_y: 0.0
acc_lim_theta: 3.2
decel_lim_x: -2.5
decel_lim_y: 0.0
decel_lim_theta: -3.2
vx_samples: 20
vy_samples: 5
vtheta_samples: 20
sim_time: 1.7
linear_granularity: 0.05
angular_granularity: 0.025
transform_tolerance: 0.2
trans_stopped_velocity: 0.25
short_circuit_trajectory_evaluation: True
stateful: True
critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
BaseObstacle.scale: 0.02
PathAlign.scale: 32.0
PathAlign.forward_point_distance: 0.1
GoalAlign.scale: 24.0
GoalAlign.forward_point_distance: 0.1
PathDist.scale: 32.0
GoalDist.scale: 24.0
RotateToGoal.scale: 32.0
RotateToGoal.slowing_factor: 5.0
RotateToGoal.lookahead_time: -1.0
This is a more verbose output. Error is after "Path end point..."
[INFO] [1722367293.982505733] [controller_server]: Received a goal, begin computing control effort.
[DEBUG] [1722367293.982482334] [rcl]: Service take request succeeded: true
[DEBUG] [1722367293.982528176] [controller_server]: Selected controller: FollowPath.
[WARN] [1722367293.982615471] [controller_server]: No goal checker was specified in parameter 'current_goal_checker'. Server will use only plugin loaded general_goal_checker . This warning will appear once.
[DEBUG] [1722367293.982648793] [controller_server]: Providing path to the controller FollowPath
[DEBUG] [1722367293.985320245] [rcl]: Subscription taking message
[DEBUG] [1722367293.985906138] [rcl]: Subscription take succeeded: true
[DEBUG] [1722367293.987424069] [rcl]: Subscription taking message
[DEBUG] [1722367293.987559683] [rcl]: Subscription take succeeded: true
[DEBUG] [1722367293.988405086] [rcl]: Subscription taking message
[DEBUG] [1722367293.988482097] [rcl]: Subscription take succeeded: true
[DEBUG] [1722367293.988531262] [rcl]: Subscription taking message
[DEBUG] [1722367293.988610804] [rcl]: Subscription take succeeded: true
[DEBUG] [1722367293.988797023] [rcl]: Subscription taking message
[DEBUG] [1722367293.988832937] [rcl]: Subscription take succeeded: true
[DEBUG] [1722367293.990918153] [rcl]: Subscription taking message
[DEBUG] [1722367293.990969807] [rcl]: Subscription take succeeded: true
[DEBUG] [1722367293.994588623] [rcl]: Subscription taking message
[DEBUG] [1722367293.994644770] [rcl]: Subscription take succeeded: true
[DEBUG] [1722367294.003165560] [controller_server]: Path end point is (-2.95, -3.33)
