I'm using ROS2 Iron in Docker on my robot. The problem is that nodes can't communicate with each other. What have been done:
  1. I've run two containers in Docker with Ros Iron:
# On Robot via ssh twice
$ docker run --privileged -it --runtime nvidia --network=host ros:iron /bin/bash
  1. In both containers I've installed ros-iron-demo-nodes-cpp
# On Robot in both Docker containers
$ apt update && apt install -y ros-iron-demo-nodes-cpp
  1. Then I've run talker node in one container
# On Robot in the first container
$ source /opt/ros/iron/setup.bash
$ ros2 run demo_nodes_cpp talker
[INFO] [1720527552.878652747] [talker]: Publishing: 'Hello World: 1'
[INFO] [1720527553.878610512] [talker]: Publishing: 'Hello World: 2'
[INFO] [1720527554.878595492] [talker]: Publishing: 'Hello World: 3'
[INFO] [1720527555.878651697] [talker]: Publishing: 'Hello World: 4'
[INFO] [1720527556.878624129] [talker]: Publishing: 'Hello World: 5'
  1. In second container I've checked that ros2 can see chatter topic:
# On Robot in the second container
$ ros2 topic list
/chatter
/parameter_events
/rosout
  1. I've run listener node in second container:
# On robot in the second container
$ ros2 run demo_nodes_cpp listener
But there was no any output from this command.
  1. Then I stopped the listener node and tried to verify that second container can "hear" first container:
$ ros2 topic echo /chatter
There was no output.
  1. After that on my laptop I've run this commands:
# On my laptop
$ ros2 topic list
/chatter
/parameter_events
/rosout
data: 'Hello World: 299'
data: 'Hello World: 300'
data: 'Hello World: 301'
data: 'Hello World: 302'
And as you can see I've got output on my laptop. Technical information:
  1. Both robot and my laptop are in the same local network
  2. Local variables on Robot in both containers are the same:
# On Robot in both containers
$ printenv | grep -i ROS
ROS_VERSION=2
ROS_PYTHON_VERSION=3
AMENT_PREFIX_PATH=/opt/ros/iron
ROS_AUTOMATIC_DISCOVERY_RANGE=SUBNET
PYTHONPATH=/opt/ros/iron/lib/python3.10/site-packages
LD_LIBRARY_PATH=/opt/ros/iron/lib/aarch64-linux-gnu:/opt/ros/iron/lib
PATH=/opt/ros/iron/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
ROS_DISTRO=iron
  1. Local variables on my laptop:
# On my laptop
ROS_VERSION=2
ROS_DOMAIN_ID=0
_colcon_cd_root=/opt/ros/iron/
LD_LIBRARY_PATH=/opt/ros/iron/opt/rviz_ogre_vendor/lib:/opt/ros/iron/lib/x86_64-linux-gnu:/opt/ros/iron/lib
PATH=/opt/ros/iron/bin:/home/<my_name>//.local/bin:/home/<my_name>//.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/snap/bin
ROS_DISTRO=iron
So the question is how to fix that my containers can't communicate with each other?
Solution found:
To solve this problem it's necessary to start containers with this mount flag: -v /dev/shm:/dev/shm. This also doesn't break possibility to communicate with nodes on robot from my laptop.
There is also another way to fix it, it fully described here: https://github.com/eProsima/Fast-DDS/issues/1698#issuecomment-778039676
