Setup:
  • ROS2 version: Humble
  • Nav2 version: 1.1.15
  • Hardware: i7-10700TE CPU with 16 GB of RAM
I would like to use the Nav 2 MPPI controller to drive a forklift through a warehouse. I created a virtual corridor to test and tune the controller parameters safely.
The virtual corridor is 3.1-3.2 m wide. The robot's footprint is 2.07 x 1.08 m. It is required that the robot be able to change direction in the corridor.
Photo about the environment
The problem is that if I enable the consider_footprint parameter, the controller can't keep up the 30 Hz controller frequency and the robot drives significantly worse. I know that the SMAC planner considers the robot's footprint during planning so it is not required to enable this footprint checking in the controller. However, I would like to keep it enabled for safety reasons because the controller does not always follow the global plan.
These are my related controller, planner and costmap parameters:
planner_server:
  ros__parameters:
    planner_plugins: ["GridBased"]
    expected_planner_frequency: 1.0
    use_sim_time: False
    GridBased:
      plugin: "nav2_smac_planner/SmacPlannerLattice"
      downsample_costmap: False
      downsampling_factor: 1
      allow_unknown: False
      tolerance: 0.25
      max_iterations: 1000000
      max_on_approach_iterations: 1000
      max_planning_time: 10.0
      motion_model_for_search: "REEDS_SHEPP"
      analytic_expansion_ratio: 3.5
      analytic_expansion_max_length: 3.0
      reverse_penalty: 2.0
      change_penalty: 0.15
      cost_penalty: 2.0
      rotation_penalty: 5.0
      retrospective_penalty: 0.025
      lattice_filepath: "acker_minturn_05_costres_005.json"
      cache_obstacle_heuristic: True
      allow_reverse_expansion: True
      smooth_path: True
      smoother:
        w_smooth: 0.3
        w_data: 0.2
        tolerance: 0.0000000001 # 1.0e-10
        do_refinement: True
        refinement_num: 2
controller_server:
  ros__parameters:
    controller_frequency: 30.0
    use_sim_time: False
    min_x_velocity_threshold: 0.001
    min_theta_velocity_threshold: 0.001
    odom_topic: /odometry/filtered
    progress_checker_plugin: "progress_checker"
    goal_checker_plugins: ["general_goal_checker"]
    controller_plugin_types: ["nav2_mppi_controller::MPPIController"]
    controller_plugins: ["FollowPath"]
    # Progress checker parameters
    progress_checker:
      plugin: "nav2_controller::PoseProgressChecker"
      required_movement_radius: 0.25
      required_movement_angle: 0.25
      movement_time_allowance: 10.0
    general_goal_checker:
      plugin: "nav2_controller::SimpleGoalChecker"
      stateful: True
      xy_goal_tolerance: 0.05
      yaw_goal_tolerance: 0.05
    stopped_goal_checker:
      plugin: "nav2_controller::StoppedGoalChecker"
      trans_stopped_velocity: 0.05
      rot_stopped_velocity: 0.05
    FollowPath:
      plugin: "nav2_mppi_controller::MPPIController"
      time_steps: 90
      model_dt: 0.05
      batch_size: 2000
      vx_std: 0.15
      vy_std: 0.0
      wz_std: 0.15
      vx_max: 0.5
      vx_min: -0.5
      vy_max: 0.0
      wz_max: 0.4
      iteration_count: 1
      transform_tolerance: 0.1
      prune_distance: 3.0
      temperature: 0.3
      gamma: 0.015
      motion_model: "DiffDrive"
      visualize: false
      reset_period: 1.0
      regenerate_noise: false
      TrajectoryVisualizer:
        trajectory_step: 5
        time_step: 3
      max_robot_pose_search_dist: 5.0
      enforce_path_inversion: True
      inversion_xy_tolerance: 0.2
      inversion_yaw_tolerance: 0.4
      critics:
          "ConstraintCritic",
          "GoalCritic",
          "GoalAngleCritic",
          "CostCritic",
          "PathAlignCritic",
          "PathFollowCritic",
          "PathAngleCritic",
      ConstraintCritic:
        enabled: true
        cost_power: 1
        cost_weight: 4.0
      GoalCritic:
        enabled: true
        cost_power: 1
        cost_weight: 8.0
        threshold_to_consider: 1.4
      GoalAngleCritic:
        enabled: true
        cost_power: 1
        cost_weight: 3.0
        threshold_to_consider: 0.5
      CostCritic:
        enabled: true
        cost_power: 1
        cost_weight: 3.81
        critical_cost: 300.0
        consider_footprint: true
        collision_cost: 1000000.0
        near_goal_distance: 0.5
      PathAlignCritic:
        enabled: true
        use_path_orientations: True
        cost_power: 1
        cost_weight: 10.0
        max_path_occupancy_ratio: 0.05
        trajectory_point_step: 3
        offset_from_furthest: 20
      PathFollowCritic:
        enabled: true
        cost_power: 1
        cost_weight: 5.0
        offset_from_furthest: 5
      PathAngleCritic:
        enabled: true
        cost_power: 1
        forward_preference: false
        cost_weight: 2.2
        max_angle_to_furthest: 0.25
global_costmap:
  global_costmap:
    ros__parameters:
      always_send_full_costmap: False
      update_frequency: 1.0
      publish_frequency: 1.0
      global_frame: map
      robot_base_frame: base_link
      footprint: "[ [-0.52,-0.35], [1.55,-0.35], [ 1.55, 0.73], [-0.52, 0.73] ]"
      footprint_padding: 0.08
      robot_radius: 0.22
      resolution: 0.05
      track_unknown_space: true
      plugins: ["static_layer", "obstacle_layer", "inflation_layer"]
      filters: ["keepout_filter", "inflation_layer"]
      keepout_filter:
        plugin: "nav2_costmap_2d::KeepoutFilter"
        enabled: True
        filter_info_topic: "/costmap_filter_info"
      obstacle_layer:
        plugin: "nav2_costmap_2d::ObstacleLayer"
        enabled: True
        observation_sources: "scan"
        footprint_clearing_enabled: true
        scan:
          topic: /scan
          data_type: "LaserScan"
          expected_update_rate: 0.07
          max_obstacle_height: 2.0
          marking: True
          clearing: True
          inf_is_valid: False
          raytrace_max_range: 8.0
          raytrace_min_range: 0.1
          obstacle_max_range: 8.0
          obstacle_min_range: 0.1
      static_layer:
        plugin: "nav2_costmap_2d::StaticLayer"
        map_subscribe_transient_local: True
        enabled: true
        subscribe_to_updates: true
      inflation_layer:
        plugin: "nav2_costmap_2d::InflationLayer"
        enabled: True
        cost_scaling_factor: 1.5
        inflation_radius: 3.9
        inflate_unknown: false
        inflate_around_unknown: true
local_costmap:
  local_costmap:
    ros__parameters:
      update_frequency: 5.0
      publish_frequency: 2.0
      transform_tolerance: 0.3
      global_frame: odom
      rolling_window: true
      width: 8
      height: 8
      resolution: 0.05
      robot_radius: 0.22
      footprint_padding: 0.05
      plugins: ["obstacle_layer", "inflation_layer"]
      keepout_filter:
        enabled: True
      obstacle_layer:
        enabled: True
        footprint_clearing_enabled: True
        scan:
          topic: /scan
          marking: True
          clearing: True
          inf_is_valid: True
          obstacle_max_range: 7.9
      inflation_layer:
        enabled: True
From what I heard the IPC should be able to run the MPPI controller with 30 Hz and if I check the CPU loads, it is not 100% when it prints this: Control loop missed its desired rate of 30.0000Hz.
What can I do in this situation?
New contributor
vLevente is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
