I hit a performance issue when trying to use a custom message type in ROS 1 Noetic in Python. My custom message was defined like this:
# Grasp.msg
Header header
geometry_msgs/Pose pose
float32 confidence
float32 width
And an array of these messages was defined like this:
# Grasps.msg
Header header
Grasp[] grasps
Creating ~10k of these messages was taking around 0.25 seconds.
When I went to profile my code, I realized that the majority of the time (>80%) was spent creating the empty message. If I write an equivalent class/dataclass to store my message data, the overhead is not nearly this high (~20% spent creating the class) and the speed is several times faster.
Other message types (non-custom) take similarly long to generate:
Line #      Hits         Time  Per Hit   % Time  Line Contents
    23                                           def create_and_fill_msg():
    24     10001    1039578.0    103.9      4.4      for _ in range(10000):
    25     10000   12915914.0   1291.6     54.4          pose = Pose()
    26     10000    1573284.0    157.3      6.6          pose.position.x = 0
    27     10000    1304890.0    130.5      5.5          pose.position.y = 0
    28     10000    1533402.0    153.3      6.5          pose.position.z = 0
    29     10000    1412335.0    141.2      5.9          pose.orientation.x = 0
    30     10000    1374551.0    137.5      5.8          pose.orientation.y = 0
    31     10000    1363287.0    136.3      5.7          pose.orientation.z = 0
    32     10000    1222556.0    122.3      5.1          pose.orientation.w = 0
I'm curious why this is happening and if there is a way around the issue, either in how I define or how I fill my messages.
