I am trying to transform points from the camera coordinate frame to the base coordinate frame in ROS 2. Here’s my code:
import tf2_ros
import rclpy
from tf2_geometry_msgs import do_transform_point
from geometry_msgs.msg import Point
rclpy.init()
node = rclpy.create_node('transform_debug')
tf_buffer = tf2_ros.Buffer(rclpy.duration.Duration(seconds=1.0))
tf2_ros.TransformListener(tf_buffer, node)
# Transform point coordinates to the target frame.
source_frame = 'camera_depth_frame'
target_frame = 'base_link'
# get the transformation from source_frame to target_frame.
transformation = tf_buffer.lookup_transform(target_frame,
            source_frame, rclpy.time.Time(), rclpy.duration.Duration(seconds=0.1))
point_source = Point(x=0.1, y=1.2, z=2.3)
point_target = do_transform_point(transformation, point_source)
When I run this with:
ros2 launch stretch_core stretch_driver.launch.py
The code results in the following error:
transformation = tf_buffer.lookup_transform(target_frame,source_frame, rclpy.time.Time(), rclpy.duration.Duration(seconds=3.0))
  File "<stdin>", line 1, in <module>
  File "/opt/ros/humble/lib/python3.10/site-packages/tf2_ros/buffer.py", line 136, in lookup_transform
    return self.lookup_transform_core(target_frame, source_frame, time)
tf2.LookupException: "base_link" passed to lookupTransform argument target_frame does not exist
Any idea why ROS 2 cannot seem to find “base_link”, when this worked perfectly fine in ROS 1?
