Stack Exchange network consists of 183 Q&A communities including Stack Overflow, the largest, most trusted online community for developers to learn, share their knowledge, and build their careers.
ROS 2 uses DDS middleware for communication between nodes. If a microcontroller uses micro-ROS, can it communicate in the same way as ROS 2 nodes? Specifically, can MCU1 communicate with MCU2?
