I was trying to work on lidar point cloud using PCL by simulating a lidar in gazebo fortress and ROS 2. I am able to process the data but I always get the intensity as zero. Is there a way I could get the intensity of the ray or has this feature not been implemented. I am mentioning below my lidar and pcl code below:
Lidar:
<gazebo reference="${name}">
      <sensor name="${name}" type="gpu_lidar">
        <update_rate>${update_rate}</update_rate>
        <visualize>true</visualize>
        <always_on>true</always_on>
        <ignition_frame_id>${name}</ignition_frame_id>
        <lidar>
          <scan>
            <horizontal>
              <samples>${horizontal_samples}</samples>
              <resolution>1</resolution>
              <min_angle>-${pi}</min_angle>
              <max_angle>${pi}</max_angle>
            </horizontal>
            <vertical>
              <samples>${vertical_samples}</samples>
              <min_angle>-${45.0*pi/180.0}</min_angle>
              <max_angle>${45.0*pi/180.0}</max_angle>
            </vertical>
          </scan>
          <range>
            <min>${min_range}</min>
            <max>${max_range}</max>
            <resolution>0.01</resolution>
          </range>
        </lidar>
      </sensor>
    </gazebo>
PCL:
#include <rclcpp/rclcpp.hpp>
#include <sensor_msgs/msg/point_cloud2.hpp>
#include <pcl_conversions/pcl_conversions.h>
#include <pcl/point_cloud.h>
#include <pcl/point_types.h>
#include <iomanip>
using std::placeholders::_1;
class PointCloudPrinter : public rclcpp::Node
public:
  PointCloudPrinter() : Node("pointcloud_printer_cpp")
    subscription_ = this->create_subscription<sensor_msgs::msg::PointCloud2>(
        "/j100_0000/sensors/lidar3d_0/points", 10, std::bind(&PointCloudPrinter::print_pointcloud, this, _1));
private:
  void print_pointcloud(const sensor_msgs::msg::PointCloud2::SharedPtr msg)
    // Convert to PCL PointCloud with intensity
    pcl::PointCloud<pcl::PointXYZI>::Ptr pcl_cloud(new pcl::PointCloud<pcl::PointXYZI>);
    pcl::fromROSMsg(*msg, *pcl_cloud);
    // Print the point cloud data
    for (const auto &point : pcl_cloud->points)
      RCLCPP_INFO(this->get_logger(), "(%.3f, %.3f, %.3f, %.3f)", point.x, point.y, point.z, point.intensity);
    RCLCPP_INFO(this->get_logger(), "-----\n"); // Separator
  rclcpp::Subscription<sensor_msgs::msg::PointCloud2>::SharedPtr subscription_;
int main(int argc, char *argv[])
  rclcpp::init(argc, argv);
  rclcpp::spin(std::make_shared<PointCloudPrinter>());
  rclcpp::shutdown();
  return 0;
Please let me know if any additional information is needed
