I am working on project that requires lots of PWM channels and decided to use PCA9685 and Raspberry Pi 4B as my controller, which I've never used. I installed Ubuntu 22.04LTS in order to use ROS-humble and was wondering how do I set up the PCA9685, I got it working with Arduino Nano but can't seem to figure out on how to set this thing up on the Pi. I tried follow the Adafruit tutorial but I ran into some issues which I am assuming is because it is meant for RaspbianOS. Does anyone have link to a tutorial or advice on how to set this thing up.
This pwm board is pretty common so I was hoping to find someone who went through this exact problem.
Notes: if example code can be provided to test, that would also be great.
Somethings I've tried.
import time
import board
from adafruit_pca9685 import PCA9685
from adafruit_motor import servo
#Create the I2C bus interface.
i2c = board.I2C()
#servo specifications
USMIN = 600
USMAX = 2400
USNEUTREL = 1500
SERVO_FREQ = 60
SERVO_MIN = 150
SERVO_MAX = 600
ACT_RANGE = 180
#Create a simple PCA9685 class instance
pca = PCA9685(i2c)
# Set the PWM frequency to 60hz.
pca.frequency = 60
#Set the PWM duty cycle for channel zero to 50%. duty_cycle is 16 bits to match other PWM objects
#but the PCA9685 will only actually give 12 bits of resolution
pca.channels[0].duty_cycle = 0x7FFF #look more into this
servo0 = servo.Servo(pca.channels[0],ACT_RANGE,USMIN,USMAX)
def test_servos():
    for i in range (180):
        servo0.angle = i
        time.sleep(0.03)
        servo0.angle = 180 - i
        time.sleep(0.03)
def main(args = None):
    print("Running 'test_servos' script")
    test_servos()
if __name__ == '__main__':
    main()
ERROR:
  File "/home/mcc/Desktop/servos.py", line 2, in <module>
    import board
  File "/usr/local/lib/python3.10/dist-packages/board.py", line 47, in <module>
    from adafruit_blinka.board.raspberrypi.raspi_4b import *
  File "/usr/local/lib/python3.10/dist-packages/adafruit_blinka/board/raspberrypi/raspi_4b.py", line 6, in <module>
    from adafruit_blinka.microcontroller.bcm2711 import pin
  File "/usr/local/lib/python3.10/dist-packages/adafruit_blinka/microcontroller/bcm2711/pin.py", line 5, in <module>
    from RPi import GPIO
ModuleNotFoundError: No module named 'RPi'
I've pretty sure I tried installing RPi, but I will try again later.
  • $\begingroup$ always format error messages as code for readability $\endgroup$
    – jsotola
    Commented Jun 11 at 6:04
You have to install the RPi gpio through pip.
sudo apt update
sudo apt upgrade
sudo apt install python3-pip python3-dev
pip3 install --user RPi.GPIO
The original answer is posted here Link to original answer
  • $\begingroup$ Will give it try, thanks. $\endgroup$
    – msalaz03
    Commented Jun 11 at 23:13
  • $\begingroup$ Followed your instructions and got this Requirement already satisfied: RPi.GPIO in ./.local/lib/python3.10/site-packages (0.7.1) $\endgroup$
    – msalaz03
    Commented Jun 13 at 23:44
    $\begingroup$ sudo apt-get install python3-rpi.gpio this command did for me, thanks. $\endgroup$
    – msalaz03
    Commented Jun 14 at 0:24
