I'm currently working with ROS2 and Python to process image data stored in a ROS2 bag file. My task involves extracting images from the bag, performing modifications, and then reinserting them. I am using the rosbags.rosbag2
library to interact with the ROS2 bag files and cv_bridge
to convert ROS2 images to OpenCV format (and vice versa).
Here is the specific part of my environment and task setup:
- Operating System: Ubuntu 22.04
- Programming Language: Python 3.10.12
However, I've encountered an AttributeError
when attempting to serialize the modified image back into the ROS2 message format. Here is the relevant portion of my code:
from cv_bridge import CvBridge
from rosbags.rosbag2 import Reader, Writer
from rosbags.typesys import Stores, get_typestore
bridge = CvBridge()
typestore = get_typestore(Stores.LATEST)
Image = typestore.types["sensor_msgs/msg/Image"]
with Reader(INPUT_BAGFILE) as reader, Writer(OUTPUT_BAGFILE) as writer:
writer_connection = writer.add_connection("/d435i/color/image_raw",
"sensor_msgs/msg/Image",
typestore=typestore)
for connection, timestamp, rawdata in reader.messages():
if connection.topic == "/d435i/color/image_raw":
msg = typestore.deserialize_cdr(rawdata, connection.msgtype)
img = bridge.imgmsg_to_cv2(msg, desired_encoding="rgb8")
# modify image here
bridged_image = bridge.cv2_to_imgmsg(img, encoding="rgb8")
image_message = Image(
bridged_image.header,
bridged_image.height,
bridged_image.width,
bridged_image.encoding,
bridged_image.is_bigendian,
bridged_image.step,
bridged_image.data
new_msg = typestore.serialize_cdr(image_message, "sensor_msgs/msg/Image")
writer.write(writer_connection, timestamp, new_msg)
In this case, the OUPUT_BAGFILE
is a copy of the INPUT_BAGFILE
The error I receive is:
AttributeError Traceback (most recent call last)
Input In [13], in <cell line: 4>()
13 bridged_image = bridge.cv2_to_imgmsg(img, encoding="rgb8")
14 image_message = Image(
15 bridged_image.header,
16 bridged_image.height,
21 bridged_image.data
22 )
---> 24 new_msg = typestore.serialize_cdr(image_message, 'sensor_msgs/msg/Image')
25 writer.write(writer_connection, timestamp, new_msg)
File ~/.local/lib/python3.10/site-packages/rosbags/typesys/store.py:166, in Typestore.serialize_cdr(self, message, typename, little_endian)
162 pack_into('BB', rawdata, 0, 0, little_endian)
164 func = msgdef.serialize_cdr_le if little_endian else msgdef.serialize_cdr_be
--> 166 pos = func(rawdata[4:], 0, message, self)
167 assert pos + 4 == size
168 return rawdata.toreadonly()
File <string>:20, in serialize_cdr(rawdata, pos, message, typestore)
File <string>:18, in serialize_cdr(rawdata, pos, message, typestore)
AttributeError: 'Time' object has no attribute 'sec'
I appreciate any insights or suggestions on how to resolve this error.
