So I am new to ros2 and ros2_control. I am projecting a wheelchair with a rotating 2d LiDAR, to make a cheap 3d LiDAR. My problem is, I cannot solve the controller manager issue with the rotating LiDAR, i have looked in multiple tutorials and this problem doesn't go away. I started testing just the controller manager and it doesn't seem to work, even though I have installed all the necessaries packages.
I ran this on my terminal
ros2 run controller_manager spawner joint_trajectory_controller
and this was the result
$ ros2 run controller_manager spawner joint_trajectory_controller
[INFO] [1718035424.759147266] [spawner_joint_trajectory_controller]: Waiting for '/controller_manager' node to exist
[INFO] [1718035426.783524107] [spawner_joint_trajectory_controller]: Waiting for '/controller_manager' node to exist
[INFO] [1718035428.808219884] [spawner_joint_trajectory_controller]: Waiting for '/controller_manager' node to exist
[INFO] [1718035430.832621980] [spawner_joint_trajectory_controller]: Waiting for '/controller_manager' node to exist
[ERROR] [1718035432.856900297] [spawner_joint_trajectory_controller]: Controller manager not available
[ros2run]: Process exited with failure 1
this is the code i am using for ros2_control:
controller_manager:
  ros__parameters:
    update_rate: 30
    use_sim_time: true
    joint_trajectory_controller:
      type: joint_trajectory_controller/JointTrajectoryController
    joint_state_broadcaster:
      type: joint_state_broadcaster/JointStateBroadcaster
  ros__parameters:
    joints:
      - MotorLidar
    command_interfaces:
      - position
    state_interfaces:
      - position
      - effort
      - velocity
    state_publish_rate: 30.0
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro">
    <ros2_control name="GazeboSystem" type="system">
        <hardware>
            <plugin>gazebo_ros2_control/GazeboSystem</plugin>
        </hardware>
        <joint name="MotorLidar">
            <command_interface name="position">
                <param name="min">-2</param>
                <param name="max">2</param>
                <param name="initial_value">0</param>
            </command_interface>
            <state_interface name="position" />
            <state_interface name="velocity" />
            <state_interface name="effort" />
        </joint>
    </ros2_control>
    <gazebo>
        <plugin name="diff_drive" filename="libgazebo_ros_diff_drive.so">
            <!-- Wheel Information -->
            <left_joint>MotorEsquerdo</left_joint>
            <right_joint>MotorDireito</right_joint>
            <wheel_separation>0.15</wheel_separation>
            <wheel_diameter>0.4</wheel_diameter>
            <!-- Limits -->
            <max_wheel_torque>100</max_wheel_torque>
            <max_wheel_acceleration>2.0</max_wheel_acceleration>
            <!-- Output -->
            <odometry_frame>odom</odometry_frame>
            <robot_base_frame>robot_base</robot_base_frame>
            <publish_odom>true</publish_odom>
            <publish_odom_tf>true</publish_odom_tf>
            <publish_wheel_tf>true</publish_wheel_tf>
        </plugin>
    </gazebo>
    <gazebo>
        <plugin filename="libgazebo_ros2_control" name="gazebo_ros2_control" >
            <parameters>$(find cadeira)/config/joint_controller.yaml</parameters>
        </plugin>
    </gazebo>
</robot>
this is my launch file:
import os
from ament_index_python.packages import get_package_share_directory
from launch.actions import IncludeLaunchDescription, ExecuteProcess
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch_ros.actions import Node
    package_name='cadeira'
    rsp = IncludeLaunchDescription(
                PythonLaunchDescriptionSource([os.path.join(
                    get_package_share_directory(package_name),'launch','rsp.launch.py'
                )]), launch_arguments={'use_sim_time': 'true'}.items()
    gazebo = IncludeLaunchDescription(
                    get_package_share_directory('gazebo_ros'), 'launch', 'gazebo.launch.py')]),
    spawn_entity = Node(package='gazebo_ros', executable='spawn_entity.py',
                        arguments=['-topic', 'robot_description',
                                   '-entity', 'my_bot'],
                        output='screen')
    load_joint_state_broadcaster = ExecuteProcess(
        cmd=['ros2', 'control', 'load_controller', '--set-state', 'active',
             'joint_state_broadcaster'],
        output='screen'
    load_joint_trajectory_controller = ExecuteProcess(
             'joint_trajectory_controller'],
        output='screen'
    # Launch them all!
    return LaunchDescription([
        rsp,
        gazebo,
        spawn_entity,
        load_joint_state_broadcaster,
and this is the output I get when a launch it:
$ ros2 launch cadeira launch_sim.launch.py
[INFO] [launch]: All log files can be found below /home/ic/.ros/log/2024-06-11-13-05-54-777817-ic-Nitro-AN515-51-8442
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [robot_state_publisher-1]: process started with pid [8446]
[INFO] [gzserver-2]: process started with pid [8448]
[INFO] [gzclient-3]: process started with pid [8450]
[INFO] [spawn_entity.py-4]: process started with pid [8452]
[INFO] [ros2-5]: process started with pid [8454]
[INFO] [ros2-6]: process started with pid [8456]
[robot_state_publisher-1] [INFO] [1718121956.453071547] [robot_state_publisher]: got segment ApoioBracoDireito
[robot_state_publisher-1] [INFO] [1718121956.453273800] [robot_state_publisher]: got segment ApoioBracoEsquerdo
[robot_state_publisher-1] [INFO] [1718121956.453294493] [robot_state_publisher]: got segment ApoioCostas
[robot_state_publisher-1] [INFO] [1718121956.453305103] [robot_state_publisher]: got segment ApoioLidar
[robot_state_publisher-1] [INFO] [1718121956.453313870] [robot_state_publisher]: got segment BaseDireita
[robot_state_publisher-1] [INFO] [1718121956.453322761] [robot_state_publisher]: got segment BaseEsquerda
[robot_state_publisher-1] [INFO] [1718121956.453332115] [robot_state_publisher]: got segment ColunaDireitaDianteira_2
[robot_state_publisher-1] [INFO] [1718121956.453341919] [robot_state_publisher]: got segment ColunaDireitaTraseira
[robot_state_publisher-1] [INFO] [1718121956.453351422] [robot_state_publisher]: got segment ColunaEsquerdaDianteira
[robot_state_publisher-1] [INFO] [1718121956.453360727] [robot_state_publisher]: got segment ColunaEsquerdaTraseira
[robot_state_publisher-1] [INFO] [1718121956.453369943] [robot_state_publisher]: got segment Lidar
[robot_state_publisher-1] [INFO] [1718121956.453379442] [robot_state_publisher]: got segment RodaDireitaDianteira
[robot_state_publisher-1] [INFO] [1718121956.453388548] [robot_state_publisher]: got segment RodaDireitaTraseira
[robot_state_publisher-1] [INFO] [1718121956.453398134] [robot_state_publisher]: got segment RodaEsquerdaDianteira
[robot_state_publisher-1] [INFO] [1718121956.453406878] [robot_state_publisher]: got segment RodaEsquerdaTraseira
[robot_state_publisher-1] [INFO] [1718121956.453415503] [robot_state_publisher]: got segment base_link
[robot_state_publisher-1] [INFO] [1718121956.453423873] [robot_state_publisher]: got segment robot_base
[spawn_entity.py-4] [INFO] [1718121956.961788878] [spawn_entity]: Spawn Entity started
[spawn_entity.py-4] [INFO] [1718121956.962362076] [spawn_entity]: Loading entity published on topic robot_description
[spawn_entity.py-4] /opt/ros/iron/lib/python3.10/site-packages/rclpy/qos.py:313: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead.
[spawn_entity.py-4]   warnings.warn(
[spawn_entity.py-4] [INFO] [1718121956.965476395] [spawn_entity]: Waiting for entity xml on robot_description
[spawn_entity.py-4] [INFO] [1718121956.976774027] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
[spawn_entity.py-4] [INFO] [1718121956.977335027] [spawn_entity]: Waiting for service /spawn_entity
[spawn_entity.py-4] [INFO] [1718121957.985194296] [spawn_entity]: Calling service /spawn_entity
[spawn_entity.py-4] [INFO] [1718121958.353158646] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [my_bot]
[gzserver-2] [INFO] [1718121958.392211503] [diff_drive]: Wheel pair 1 separation set to [0.150000m]
[gzserver-2] [INFO] [1718121958.392816441] [diff_drive]: Wheel pair 1 diameter set to [0.400000m]
[gzserver-2] [INFO] [1718121958.395233565] [diff_drive]: Subscribed to [/cmd_vel]
[gzserver-2] [INFO] [1718121958.403905390] [diff_drive]: Advertise odometry on [/odom]
[gzserver-2] [INFO] [1718121958.411997170] [diff_drive]: Publishing odom transforms between [odom] and [robot_base]
[gzserver-2] [INFO] [1718121958.412046172] [diff_drive]: Publishing wheel transforms between [robot_base], [MotorEsquerdo] and [MotorDireito]
[INFO] [spawn_entity.py-4]: process has finished cleanly [pid 8452]
[ros2-6] Could not contact service /controller_manager/load_controller
[ros2-5] Could not contact service /controller_manager/load_controller
[ERROR] [ros2-6]: process has died [pid 8456, exit code 1, cmd 'ros2 control load_controller --set-state active joint_trajectory_controller'].
[ERROR] [ros2-5]: process has died [pid 8454, exit code 1, cmd 'ros2 control load_controller --set-state active joint_state_broadcaster'].
github with all my files: https://github.com/Victorms4/ic-cadeira.git
    $\begingroup$ Please add the whole console output. Typically, the error happened earlier and the Waiting for 'controller_manager' node to exist is only a result of that. $\endgroup$ Commented Jun 7 at 10:51
  • $\begingroup$ That is the whole console output. I tried posting a printscreen but it doesn't seem to be loading, however I did update the console output and didn't left my own input this time. $\endgroup$ Commented Jun 10 at 16:13
  • $\begingroup$ OK you are calling the spawner only. But what about the console output when you launch your model in gazebo classic? it seems that gazebo_ros2_control was not loaded properly. $\endgroup$ Commented Jun 11 at 5:41
  • $\begingroup$ I edited in the whole console output and my launch file. The model is being properly loaded. To my knowledge I am having problems only with ros2_control and the controller_manager. Thanks for your patience, I appreciate any help! $\endgroup$ Commented Jun 11 at 16:11
There is not a single log output from gazebo_ros2_control.
By comparing your URDF with the demos, the only difference I see now is the filename: Can you try filename="libgazebo_ros2_control.so" instead?
  • $\begingroup$ It worked! After i changed that, the error logs became more clear, and I was able to correct other errors in my code. Thank you for your help and for your time! $\endgroup$ Commented Jun 12 at 17:50
