does anyone know why i cant initialize an instance of tf2_ros::buffer in ROS2 Foxy?
test_file.cpp :
#include "rclcpp/rclcpp.hpp"
#include "tf2_ros/buffer.h"
#include "tf2/convert.h"
#include "tf2_geometry_msgs/tf2_geometry_msgs.h"
rclcpp::init(argc, argv);
tf2_ros::Buffer buffer;
CMakeLists.txt:
cmake_minimum_required(VERSION 3.5)
project(test_package)
# Default to C99
if(NOT CMAKE_C_STANDARD)
set(CMAKE_C_STANDARD 99)
endif()
# Default to C++14
if(NOT CMAKE_CXX_STANDARD)
set(CMAKE_CXX_STANDARD 14)
endif()
if(CMAKE_COMPILER_IS_GNUCXX OR CMAKE_CXX_COMPILER_ID MATCHES "Clang")
add_compile_options(-Wall -Wextra -Wpedantic)
endif()
# find dependencies
find_package(rclcpp REQUIRED)
find_package(tf2_ros REQUIRED)
find_package(tf2 REQUIRED)
find_package(geometry_msgs REQUIRED)
# uncomment the following section in order to fill in
# further dependencies manually.
# find_package(<dependency> REQUIRED)
add_executable(test_package src/test_file.cpp)
include_directories(include)
${tf2_ros_INCLUDE_DIRS}
ament_target_dependencies(test_package
tf2_ros
tf2
geometry_msgs
if(BUILD_TESTING)
find_package(ament_lint_auto REQUIRED)
# the following line skips the linter which checks for copyrights
# uncomment the line when a copyright and license is not present in all source files
#set(ament_cmake_copyright_FOUND TRUE)
# the following line skips cpplint (only works in a git repo)
# uncomment the line when this package is not in a git repo
#set(ament_cmake_cpplint_FOUND TRUE)
ament_lint_auto_find_test_dependencies()
endif()
ament_package()
package.xml:
<?xml version="1.0"?>
<?xml-model href="http://download.ros.org/schema/package_format3.xsd" schematypens="http://www.w3.org/2001/XMLSchema"?>
<package format="3">
<name>test_package</name>
<version>0.0.0</version>
<description>TODO: Package description</description>
<maintainer email="[email protected]">bryan</maintainer>
<license>TODO: License declaration</license>
<buildtool_depend>ament_cmake</buildtool_depend>
<depend>tf2</depend>
<depend>tf2_ros</depend>
<depend>rclcpp</depend>
<depend>geometry_msgs</depend>
<test_depend>ament_lint_auto</test_depend>
<test_depend>ament_lint_common</test_depend>
<export>
<build_type>ament_cmake</build_type>
</export>
</package>
I'm getting the following error:
error: no matching function for call to ‘tf2_ros::Buffer::Buffer()’
9 | tf2_ros::Buffer buffer;
Thank you very much !
