the robot is ros controlled but the problem is that, it has wheels in front and caster at back, so when it turns around its axis, when near the wall it collides with the wall, we are using trajectory planner as local and global planner and localization is being done using amcl, is there any work around to let ros know that there are wheels at the front instead of middle so you have to make some adjustments to turn?
