In my gazebo simulation my robot fails to maintain itself. It falls over in the spawn and starts to vibrate by itself. There were multiple terminal errors. While fixing these errors, I sometimes cause another problem:
The published robot description file (urdf) seems not to be genuine
I don't always get this error. Sometimes I do, sometimes I don't.
  • What causing my urdf file to be not genuine?
  • Why is my robot falling over spawn? I know that many reasons for this are not having proper controllers which I fixed it in my recent post with Gazebo_ros2_control library, not having proper damping and friction values, not having proper inertia values and not having a proper PID gains. If there are more reasons I want to know and how can I also add PID gains to my project. For now I will only add my urdf file but if you suspect from anything let me know.
My urdf file:
<?xml version="1.0" ?>
<!-- |    This document was autogenerated by xacro from octobot.xacro                  | -->
<!-- |    EDITING THIS FILE BY HAND IS NOT RECOMMENDED                                 | -->
<robot name="octobot">
  <material name="silver">
    <color rgba="0.700 0.700 0.700 1.000"/>
  </material>
  <transmission name="doner12_tran">
    <type>transmission_interface/SimpleTransmission</type>
    <joint name="doner12">
      <hardwareInterface>EffortJointInterface</hardwareInterface>
    </joint>
    <actuator name="doner12_actr">
      <mechanicalReduction>10</mechanicalReduction>
    </actuator>
  </transmission>
  <transmission name="doner23_tran">
    <joint name="doner23">
    </joint>
    <actuator name="doner23_actr">
    </actuator>
  </transmission>
  <transmission name="doner34_tran">
    <joint name="doner34">
    </joint>
    <actuator name="doner34_actr">
    </actuator>
  </transmission>
  <transmission name="doner45_tran">
    <joint name="doner45">
    </joint>
    <actuator name="doner45_actr">
    </actuator>
  </transmission>
  <transmission name="doner56_tran">
    <joint name="doner56">
    </joint>
    <actuator name="doner56_actr">
    </actuator>
  </transmission>
  <transmission name="doner67_tran">
    <joint name="doner67">
    </joint>
    <actuator name="doner67_actr">
    </actuator>
  </transmission>
  <gazebo>
    <plugin filename="libgazebo_ros2_control.so" name="gazebo_ros2_control">
      <parameters>/home/dogukanyilmaz/ws_octobot/src/cores/octobot_config/config/ros2_controllers.yaml</parameters>
    </plugin>
  </gazebo>
  <gazebo reference="base_link">
    <material>Gazebo/Silver</material>
    <mu1>0.2</mu1>
    <mu2>0.2</mu2>
    <self_collide>true</self_collide>
    <gravity>true</gravity>
  </gazebo>
  <gazebo reference="Motor2Gv_1">
    <mu1>0.2</mu1>
    <mu2>0.2</mu2>
  </gazebo>
  <gazebo reference="Motor3Gv_1">
    <mu1>0.2</mu1>
    <mu2>0.2</mu2>
  </gazebo>
  <gazebo reference="Motor4Gv_1">
    <mu1>0.2</mu1>
    <mu2>0.2</mu2>
  </gazebo>
  <gazebo reference="Motor5Gv_1">
    <mu1>0.2</mu1>
    <mu2>0.2</mu2>
  </gazebo>
  <gazebo reference="Motor6Gv_1">
    <mu1>0.2</mu1>
    <mu2>0.2</mu2>
  </gazebo>
  <gazebo reference="Motor7Gv_1">
    <mu1>0.2</mu1>
    <mu2>0.2</mu2>
  </gazebo>
  <link name="base_link">
    <inertial>
      <origin rpy="0 0 0" xyz="0.01104339129651807 -5.25334719245186e-08 0.09293988490750445"/>
      <mass value="17.613743236958385"/>
      <inertia ixx="0.087346" ixy="-0.0" ixz="0.000413" iyy="0.099484" iyz="0.0" izz="0.061677"/>
    </inertial>
    <visual>
      <origin rpy="0 0 0" xyz="0 0 0"/>
      <geometry>
        <mesh filename="file:///home/dogukanyilmaz/ws_octobot/src/cores/octobot_description/meshes/base_link.stl" scale="0.001 0.001 0.001"/>
      </geometry>
      <material name="silver"/>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <link name="Motor2Gv_1">
    <inertial>
      <origin rpy="0 0 0" xyz="0.0073547207227992635 -5.7183835097550754e-08 0.13244866550568501"/>
      <mass value="14.13180132167806"/>
      <inertia ixx="0.05358" ixy="-0.0" ixz="-0.002639" iyy="0.052304" iyz="0.0" izz="0.029049"/>
    </inertial>
    <visual>
      <origin rpy="0 0 0" xyz="-0.0 -0.0 -0.174"/>
      <geometry>
        <mesh filename="file:///home/dogukanyilmaz/ws_octobot/src/cores/octobot_description/meshes/Motor2Gv_1.stl" scale="0.001 0.001 0.001"/>
      </geometry>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <link name="Motor3Gv_1">
    <inertial>
      <origin rpy="0 0 0" xyz="-0.040302427728824475 -3.1776755710503087e-08 0.14852969258891868"/>
      <mass value="9.34356309497989"/>
      <inertia ixx="0.04708" ixy="0.0" ixz="0.012293" iyy="0.053199" iyz="-0.0" izz="0.020547"/>
    </inertial>
    <visual>
      <origin rpy="0 0 0" xyz="-0.059 0.0 -0.326"/>
      <geometry>
        <mesh filename="file:///home/dogukanyilmaz/ws_octobot/src/cores/octobot_description/meshes/Motor3Gv_1.stl" scale="0.001 0.001 0.001"/>
      </geometry>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <link name="Motor4Gv_1">
    <inertial>
      <origin rpy="0 0 0" xyz="-0.0030612425184283498 -3.0946477218760627e-06 0.1067843579424047"/>
      <mass value="8.873874448445003"/>
      <inertia ixx="0.023613" ixy="0.0" ixz="0.000801" iyy="0.023432" iyz="1e-06" izz="0.012203"/>
    </inertial>
    <visual>
      <origin rpy="0 0 0" xyz="0.0 0.0 -0.5455"/>
      <geometry>
        <mesh filename="file:///home/dogukanyilmaz/ws_octobot/src/cores/octobot_description/meshes/Motor4Gv_1.stl" scale="0.001 0.001 0.001"/>
      </geometry>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <link name="Motor5Gv_1">
    <inertial>
      <origin rpy="0 0 0" xyz="0.02928590541122761 2.9599701849593294e-05 0.14797355123897027"/>
      <mass value="9.684238619334375"/>
      <inertia ixx="0.049575" ixy="-7e-06" ixz="-0.012451" iyy="0.056529" iyz="-1.3e-05" izz="0.021122"/>
    </inertial>
    <visual>
      <origin rpy="0 0 0" xyz="0.0495 5e-05 -0.6725"/>
      <geometry>
        <mesh filename="file:///home/dogukanyilmaz/ws_octobot/src/cores/octobot_description/meshes/Motor5Gv_1.stl" scale="0.001 0.001 0.001"/>
      </geometry>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <link name="Motor6Gv_1">
    <inertial>
      <origin rpy="0 0 0" xyz="0.0011632770512901751 1.17570137097191e-06 0.09112293887057576"/>
      <mass value="6.164349978605796"/>
      <inertia ixx="0.013483" ixy="-1e-06" ixz="-0.000289" iyy="0.013993" iyz="-0.0" izz="0.00637"/>
    </inertial>
    <visual>
      <origin rpy="0 0 0" xyz="0.0 -0.0 -0.8933"/>
      <geometry>
        <mesh filename="file:///home/dogukanyilmaz/ws_octobot/src/cores/octobot_description/meshes/Motor6Gv_1.stl" scale="0.001 0.001 0.001"/>
      </geometry>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <link name="Motor7Gv_1">
    <inertial>
      <origin rpy="0 0 0" xyz="-0.02716716791682726 -2.753113110725478e-05 0.09747913986651802"/>
      <mass value="5.870034266249876"/>
      <inertia ixx="0.014009" ixy="-3e-06" ixz="0.003344" iyy="0.016521" iyz="3e-06" izz="0.008501"/>
    </inertial>
    <visual>
      <origin rpy="0 0 0" xyz="-0.0435 -4.4e-05 -1.0093"/>
      <geometry>
        <mesh filename="file:///home/dogukanyilmaz/ws_octobot/src/cores/octobot_description/meshes/Motor7Gv_1.stl" scale="0.001 0.001 0.001"/>
      </geometry>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <link name="world"></link>
  <joint name="fixed" type="fixed">
    <parent link="world"/>
    <child link="base_link"/>
  </joint>
  <joint name="doner12" type="continuous">
    <origin rpy="0 0 0" xyz="0.0 0.0 0.174"/>
    <parent link="base_link"/>
    <child link="Motor2Gv_1"/>
    <dynamics damping="10.0" friction="10.0"/>
    <axis xyz="0.0 -0.0 -1.0"/>
  </joint>
  <joint name="doner23" type="continuous">
    <origin rpy="0 0 0" xyz="0.059 -0.0 0.152"/>
    <parent link="Motor2Gv_1"/>
    <child link="Motor3Gv_1"/>
    <axis xyz="-1.0 0.0 0.0"/>
  </joint>
  <joint name="doner34" type="continuous">
    <origin rpy="0 0 0" xyz="-0.059 0.0 0.2195"/>
    <parent link="Motor3Gv_1"/>
    <child link="Motor4Gv_1"/>
    <axis xyz="0.0 0.0 -1.0"/>
  </joint>
  <joint name="doner45" type="continuous">
    <origin rpy="0 0 0" xyz="-0.0495 -5e-05 0.127"/>
    <parent link="Motor4Gv_1"/>
    <child link="Motor5Gv_1"/>
    <axis xyz="0.999999 0.001011 0.0"/>
  </joint>
  <joint name="doner56" type="continuous">
    <origin rpy="0 0 0" xyz="0.0495 5e-05 0.2208"/>
    <parent link="Motor5Gv_1"/>
    <child link="Motor6Gv_1"/>
  </joint>
  <joint name="doner67" type="continuous">
    <origin rpy="0 0 0" xyz="0.0435 4.4e-05 0.116"/>
    <parent link="Motor6Gv_1"/>
    <child link="Motor7Gv_1"/>
    <axis xyz="-0.999999 -0.001011 0.0"/>
  </joint>
    <ros2_control name="GazeboSystem" type="system">
      <hardware>
        <plugin>gazebo_ros2_control/GazeboSystem</plugin>
      </hardware>
        <command_interface name="position"/>
        <state_interface name="position">
          <param name="initial value">0.0</param>
        </state_interface>
        <state_interface name="velocity"/>
      </joint>
        </state_interface>
      </joint>
        </state_interface>
      </joint>
        </state_interface>
      </joint>
        </state_interface>
      </joint>
        </state_interface>
      </joint>
    </ros2_control>
</robot>
12
  • $\begingroup$ can you add the full log please? $\endgroup$ Commented May 14 at 12:34
  • $\begingroup$ and add also the ROS distro you are using $\endgroup$ Commented May 14 at 12:34
  • $\begingroup$ @ChristophFroehlich I am using iron, I stopped getting the error but falling problem continiues and according to this log, controllers do indeed properly load. Here is the full log: [link] (pastebin.com/eEUJy0vc) Edit: I fixed the link and paste issue $\endgroup$ Commented May 14 at 12:42
  • $\begingroup$ what do you mean by falling down? as if the motors have no power, or "exploding"? The latter is typical for wrong inertia/mass values. $\endgroup$ Commented May 14 at 12:52
  • $\begingroup$ joint_trajectory_controller should hold the position on activation. And you use position interface, this should be ideal in gazebo_ros2_control without the need for any PID tuning. $\endgroup$ Commented May 14 at 12:53
I have had a robot fall over when spawning because it was spawning in the ground. I am not sure that is the case here but making sure it spawns a centimeter above the ground has fixed this issue for me.
  • $\begingroup$ So should add something like this to my first link after dummy world link? ' <axis xyz="0.0 -0.0 0.01"/>' $\endgroup$ Commented May 14 at 13:04
  • $\begingroup$ I have always done it by doing this: gazebo_spawner = Node( package='gazebo_ros', executable='spawn_entity.py', output='screen', arguments=["-topic", "/robot_description", "-entity", "robot", '-z', LaunchConfiguration('z_pos')]) and DeclareLaunchArgument('z_pos', default_value='1.6'), $\endgroup$
    – McQueenPC
    Commented May 14 at 13:09
    $\begingroup$ Solved the problem thanks for everything. I have a new error but atleast it worked :D $\endgroup$ Commented May 14 at 13:37
  • A robot might fall over if the controller could not be loaded properly.
  • The URDF error can happen if you have configured joints which are not included in your URDF, see the release notes here (only applies if you use Jazzy or Rolling).
  • gazebo_ros2_contol does not support transmissions, which you have added in your URDF.
5
  • $\begingroup$ Transmissions are auto-generated by ros2. I created this urdf file from xacro file which was obtained after the conversion from fusion. I commented the transmission part didnt not change anything. $\endgroup$ Commented May 14 at 12:51
  • $\begingroup$ ROS 2 does not auto-generate anything. You mean the moveit2 wizard? However, ros2_control does not use this information anyways, so it was expected to not change anything. $\endgroup$ Commented May 14 at 12:58
  • $\begingroup$ I used the command xacro model.xacro > model.urdf However you are right about the auto-generate. I am not sure what converts it. $\endgroup$ Commented May 14 at 13:05
  • $\begingroup$ xacro only does evaluate your xacro commands, but does not auto-add the transmissions. $\endgroup$ Commented May 14 at 13:08
  • $\begingroup$ Yes sorry what mean is that generated from this exporter: github.com/syuntoku14/fusion2urdf $\endgroup$ Commented May 14 at 13:10
