Is it possible to enable/disable the 4 Ioni drives mounted in Ionicube individually? It appears with IoniCube that enable/disable applies to all Ioni drives simultaneously. However, Ionicube 1X does appear to have enable/disable for individual Ioni drives. Can you confirm?
I wish to control the enable/disable state of each Ioni drive separately. And if possible to do this on IoniCube.
Most grateful for your help!
Best wishes, Mark
The IONICUBE has global enable and STO inputs, so all IONI drives are enabled/disabled simultaneously. And thus, enabling a single IONI drive is not possible.
The IONICUBE 1X only hosts a single IONI drive, and thus it's enable and STO inputs control only that drive.
