I'm trying to use KinectV2 with ROS2 Humble, in all the research I've done there's no further information than in WIP codes that didn't help me a lot. I need depth data and point cloud info for tracking humans or dynamic objects. Does anyone know where can I find a source code or could give me any advice of previous works? Please and thanks.
Have you tried kinect2_ros2 package? I am using this package to run kinect v2 on ros2 humble。 Point cloud and depth images are captured correctly and working fine. However, in my case there was an error error: no matching functionwhen building, so I had to modify the line 209 of the depth_registration_opencl.cpp。
cl::Program::Sources source(1, std::make_pair(sourceCode.c_str(), sourceCode.length()));
cl::Program::Sources source;
source.emplace_back(sourceCode.c_str(), sourceCode.length());
  • $\begingroup$ Could you be more specific about the modification? Please edit and update your answer. $\endgroup$ Commented May 9 at 4:56
  • $\begingroup$ your answer becomes useless when the link dies ... at least explain what package you are talking about $\endgroup$
    – jsotola
    Commented May 19 at 18:24
