I have a boolean launch argument as follows
    use_custom_controller   =   LaunchConfiguration("use_custom_controller")
    launch_description.add_action(
        DeclareLaunchArgument(
            "use_custom_controller",
            default_value   =   "false",
            description     =   "If True loads custom controller else diff_drive_controller"
I would like to use this argument as a conditional expression to change the value of a string variable called default_controller.
For example,
if use_custom_controller:
    default_controller = "custom_controller"
else:
    default_controller = "diff_drive_controller"
How can I achieve this in a launch script of ros2 ?
The simpler approach is to have two spawners with different arguments and your boolean used in the launch.conditions.IfCondition.
Otherwise you have to use opaque functions
from launch.actions import OpaqueFunction
from launch_ros.actions import Node
from launch.substitutions import LaunchConfiguration
def evaluate_launchconfig(context, *args, **kwargs):
    if use_custom_controller.evaluate(context):
    else:
    return Node(
        package="controller_manager",
        executable="spawner",
        arguments=[default_controller, "-c", "/controller_manager"],
        OpaqueFunction(function=evaluate_launchconfig),
