I am a beginner in ROS and CARLA. I set up Carla ROS Bridge package using the steps mentioned in https://carla.readthedocs.io/projects/ros-bridge/en/latest/run_ros/ after installing ROS bridge from the Github repository.
When I am trying to run ROS bridge using command roslaunch carla_ros_bridge carla_ros_bridge.launch
, I am receiving this error.
... logging to /home/carla-sim/.ros/log/bbb68f3c-f518-11ee-aad8-0242ac110002/roslaunch-cef764316090-3253.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
started roslaunch server http://cef764316090:41235/
SUMMARY
PARAMETERS
* /carla_ros_bridge/ego_vehicle_role_name: ["hero", "ego_veh...
* /carla_ros_bridge/fixed_delta_seconds: 0.05
* /carla_ros_bridge/host: localhost
* /carla_ros_bridge/passive: False
* /carla_ros_bridge/port: 2000
* /carla_ros_bridge/register_all_sensors: True
* /carla_ros_bridge/synchronous_mode: True
* /carla_ros_bridge/synchronous_mode_wait_for_vehicle_control_command: False
* /carla_ros_bridge/timeout: 2
* /carla_ros_bridge/town: Town01
* /rosdistro: noetic
* /rosversion: 1.16.0
* /use_sim_time: True
NODES
carla_ros_bridge (carla_ros_bridge/bridge.py)
auto-starting new master
process[master]: started with pid [3277]
setting /run_id to bbb68f3c-f518-11ee-aad8-0242ac110002
process[rosout-1]: started with pid [3303]
started core service [/rosout]
process[carla_ros_bridge-2]: started with pid [3310]
File "/root/carla-ros-bridge/catkin_ws/src/ros-bridge/carla_ros_bridge/src/carla_ros_bridge/bridge.py", line 24, in <module>
import carla
File "/opt/carla-simulator/PythonAPI/carla/dist/carla-0.9.15-py3.7-linux-x86_64.egg/carla/__init__.py", line 8, in <module>
File "/opt/carla-simulator/PythonAPI/carla/dist/carla-0.9.15-py3.7-linux-x86_64.egg/carla/libcarla.py", line 9, in <module>
File "/opt/carla-simulator/PythonAPI/carla/dist/carla-0.9.15-py3.7-linux-x86_64.egg/carla/libcarla.py", line 3, in __bootstrap__
ImportError: No module named util
================================================================================REQUIRED process [carla_ros_bridge-2] has died!
process has died [pid 3310, exit code 1, cmd /root/carla-ros-bridge/catkin_ws/src/ros-bridge/carla_ros_bridge/src/carla_ros_bridge/bridge.py __name:=carla_ros_bridge __log:=/home/carla-sim/.ros/log/bbb68f3c-f518-11ee-aad8-0242ac110002/carla_ros_bridge-2.log].
log file: /home/carla-sim/.ros/log/bbb68f3c-f518-11ee-aad8-0242ac110002/carla_ros_bridge-2*.log
Initiating shutdown!
[carla_ros_bridge-2] killing on exit
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
I searched it in the internet and found some answers which were for python2.7
version, but I am using python3.7
/usr/bin/python3 -> /etc/alternatives/python3 -> /usr/bin/python3.7
