Is it possible to fetch the current encoder position of a drive with the old SimpleMotion library (not V2) and a Granite Devices VSD-E through the smRawCommand(...)
function?
Have you checked the SimpleMotion library files yet? You can get them from here.
Please note that the old version for SimpleMotion is not supported anymore.
1$\begingroup$ Please note if you want to promote your own product/blog you must disclose your affiliation, otherwise your answer may be flagged as spam. Please read How to not be a spammer $\endgroup$ – DavidPostill Feb 27 '17 at 14:37
$\begingroup$ If you are not affiliated with the site, I recommend you mention the fact to prevent flags. $\endgroup$ – CalvT May 8 '17 at 18:30
