While trying to transfer my robot to the Gazebo environment, I get an error like this:
[ERROR] [1712090101.761754170, 0.341000000]: This robot has a joint named "screw_right_first_2_to_right_first_joint_1" which is not in the gazebo model.
[FATAL] [1712090101.761854037, 0.341000000]: Could not initialize robot simulation interface
I looked at many resources but couldn't find the solution.
My config file is as follows:
# Publish all joint states -----------------------------------
joint_state_controller:
  type: joint_state_controller/JointStateController
  publish_rate: 50
# Position Controllers ---------------------------------------
right1_position_controller:
  type: effort_controllers/JointPositionController
  joint: screw_right_first_2_to_right_first_joint_1
  pid: {p: 100.0, i: 0.01, d: 10.0}
The relevant part of my xacro model file is as follows:
<!-- Transmissions for ROS Control -->
<xacro:macro name="transmission_block" params="joint_name">
    <transmission name="tran1">
        <type>transmission_interface/SimpleTransmission</type>
        <joint name="${joint_name}">
            <hardwareInterface>hardware_interface/EffortJointInterface</hardwareInterface>
        </joint>
        <actuator name="motor1">
            <mechanicalReduction>1</mechanicalReduction>
        </actuator>
    </transmission>
</xacro:macro>
<!-- Revolute joints -->
<xacro:transmission_block joint_name="screw_right_first_2_to_right_first_joint_1"/>
<!-- ros_control plugin -->
<gazebo>
    <plugin name="gazebo_ros_control" filename="libgazebo_ros_control.so">
        <robotNamespace>/</robotNamespace>
    </plugin>
</gazebo>
screw_right_first_2_to_right_first_joint_1 is defined at the top of my xacro file for a joint with this name. I even get an error defining this the second time. This way I maintained control. I am giving this part because my code file is too long.
The content of the joint.launch file I created is as follows:
<launch>
  <include file="$(find test_urdf)/launch/gazebo.launch" />
  <rosparam file="$(find test_urdf)/config/joints.yaml" command="load"/>
  <!-- load the controllers -->
  <node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
    output="screen" ns="/test_urdf" args="joint_state_controller right1_position_controller"/>
  <!-- convert joint states to TF transforms for rviz, etc -->
  <node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher"
    respawn="false" output="screen">
    <remap from="/joint_states" to="/test_urdf/joint_states" />
  </node>
</launch>
The macro I defined as inertial_matrix is as follows:
<!-- Inertial matrix -->
<xacro:macro name="inertial_matrix" params="mass">
    <inertial>
        <origin xyz="0 0 0" rpy="0 0 0" />
        <mass value="${mass}" />
        <inertia ixx="1.0" ixy="0.0" ixz="0.0" iyy="0.5" iyz="0.0" izz="1.0" />
    </inertial>
</xacro:macro>
I added this matrix and collision values to the links.
At the same time, I can view my robot completely in the RVIZ environment. But when it comes to the gazebo environment, unfortunately I cannot view my robot fully.
I checked these codes many times and researched in many places, but unfortunately I could not get any results.
Can you help me?
[EDIT-1]-----
I just realized this:
rostopic echo /test_urdf/joint_states
after running the command "WARNING: no messages received and simulated time is active. Is /clock being published?" I got the error. To solve this, I set the use_sim_time value to false in the gazebo.launch file, but it still didn't work.
[EDIT-2]-----
My robot's xacro file is as follows. Since it was a bit long, I shortened some parts and put "..."
<?xml version="1.0" ?>
<robot name="test_urdf" xmlns:xacro="http://ros.org/wiki/xacro">
        <inertial>
        </inertial>
    </xacro:macro>
            </joint>
            </actuator>
        </transmission>
    </xacro:macro>
    <!-- Legs -->
    <xacro:macro name="leg" params="direction order">
        <link name="base_cyc_${direction}_${order}">
            <visual>
            </visual>
            <collision>
            </collision>
            <xacro:inertial_matrix mass="1"/>
        </link>
        <!-- base_link to base_cyc_${direction}_${order}-->
        <joint name="base_link_to_base_cyc_${direction}_${order}" type="fixed">
            <parent link="base_link" />
            <child link="base_cyc_${direction}_${order}" />
        </joint>
        <link name="screw_${direction}_${order}_1"></link>
        <joint name="base_cyc_${direction}_${order}_to_screw_${direction}_${order}_1" type="fixed">
            <parent link="base_cyc_${direction}_${order}" />
            <child link="screw_${direction}_${order}_1" />
        </joint>
        <link name="${direction}_${order}_joint_piece_1">
            <visual>
            </visual>
            <collision>
            </collision>
            <xacro:inertial_matrix mass="0.5"/>
        </link>
        <!-- screw_${direction}_${order}_1 to ${direction}_${order}_joint_piece_1-->
        <joint name="screw_${direction}_${order}_1_to_${direction}_${order}_joint_piece_1" type="fixed">
            <parent link="screw_${direction}_${order}_1" />
            <child link="${direction}_${order}_joint_piece_1" />
        </joint>
        <link name="screw_${direction}_${order}_2"></link>
        <!-- ${direction}_${order}_joint_piece_1 to screw_${direction}_${order}_2-->
        <joint name="${direction}_${order}_joint_piece_1_to_screw_${direction}_${order}_2" type="fixed">
            <parent link="${direction}_${order}_joint_piece_1" />
            <child link="screw_${direction}_${order}_2" />
        </joint>
        <link name="${direction}_${order}_joint_1">
            <visual>
            </visual>
            <collision>
            </collision>
        </link>
        <!-- screw_${direction}_${order}_2 to ${direction}_${order}_joint_1 -->
        <joint name="screw_${direction}_${order}_2_to_${direction}_${order}_joint_1" type="revolute">
            <parent link="screw_${direction}_${order}_2" />
            <child link="${direction}_${order}_joint_1" />
        </joint>
        <link name="screw_${direction}_${order}_3"></link>
        <!-- ${direction}_${order}_joint_1 to screw_${direction}_${order}_3-->
        <joint name="${direction}_${order}_joint_1_to_screw_${direction}_${order}_3" type="fixed">
            <parent link="${direction}_${order}_joint_1" />
            <child link="screw_${direction}_${order}_3" />
        </joint>
        <link name="${direction}_${order}_joint_2">
            <visual>
            </visual>
            <collision>
            </collision>
        </link>
        <!-- screw_${direction}_${order}_3 to ${direction}_${order}_joint_2 -->
        <joint name="screw_${direction}_${order}_3_to_${direction}_${order}_joint_2" type="fixed">
            <parent link="screw_${direction}_${order}_3" />
            <child link="${direction}_${order}_joint_2" />
        </joint>
        <link name="screw_${direction}_${order}_4"></link>
        <!-- ${direction}_${order}_joint_2 to screw_${direction}_${order}_4 -->
        <joint name="${direction}_${order}_joint_2_to_screw_${direction}_${order}_4" type="revolute">
            <parent link="${direction}_${order}_joint_2" />
            <child link="screw_${direction}_${order}_4" />
        </joint>
        <link name="${direction}_${order}_joint_piece_2">
            <visual>
            </visual>
            <collision>
            </collision>
        </link>
        <!-- screw_${direction}_${order}_3 to ${direction}_${order}_joint_piece_2 -->
        <joint name="screw_${direction}_${order}_4_to_${direction}_${order}_joint_piece_2" type="fixed">
            <parent link="screw_${direction}_${order}_4" />
            <child link="${direction}_${order}_joint_piece_2" />
        </joint>
        <link name="${direction}_${order}_cyc_1">
            <visual>
            </visual>
            <collision>
            </collision>
        </link>
        <!-- ${direction}_${order}_joint_piece_2 to  ${direction}_${order}_cyc_1 -->
        <joint name="${direction}_${order}_joint_piece_2_to_${direction}_${order}_joint2" type="fixed">
            <parent link="${direction}_${order}_joint_piece_2" />
            <child link="${direction}_${order}_cyc_1" />
        </joint>
        <link name="${direction}_${order}_joint_3">
            <visual>
            </visual>
            <collision>
            </collision>
        </link>
        <!--  ${direction}_${order}_cyc_1 to ${direction}_${order}_joint_3 -->
        <joint name="${direction}_${order}_cyc_1_to_${direction}_${order}_joint_3" type="fixed">
            <parent link="${direction}_${order}_cyc_1" />
            <child link="${direction}_${order}_joint_3" />
        </joint>
        <link name="screw_${direction}_${order}_5"></link>
        <!-- ${direction}_${order}_joint_3 to screw_${direction}_${order}_5 -->
        <joint name="${direction}_${order}_joint_3_to_screw_${direction}_${order}_5" type="revolute">
            <parent link="${direction}_${order}_joint_3" />
            <child link="screw_${direction}_${order}_5" />
        </joint>
        <link name="${direction}_${order}_joint_piece_3">
            <visual>
            </visual>
            <collision>
            </collision>
        </link>
        <!-- screw_${direction}_${order}_5 to ${direction}_${order}_joint_piece_3 -->
        <joint name="screw_${direction}_${order}_5_to_${direction}_${order}_joint_piece_3" type="fixed">
            <parent link="screw_${direction}_${order}_5" />
            <child link="${direction}_${order}_joint_piece_3" />
        </joint>
        <link name="${direction}_${order}_cyc_2">
            <visual>
            </visual>
            <collision>
            </collision>
        </link>
        <!-- ${direction}_${order}_joint_piece_3 to ${direction}_${order}_cyc_2 -->
        <joint name="${direction}_${order}_joint_piece_3_to_${direction}_${order}_cyc_2" type="fixed">
            <parent link="${direction}_${order}_joint_piece_3" />
            <child link="${direction}_${order}_cyc_2" />
        </joint>
        <!-- GAZEBO REFERENCES -->
        <gazebo reference="base_cyc_${direction}_${order}">
            <material>Gazebo/Black</material>
        </gazebo>
        <gazebo reference="${direction}_${order}_joint_piece_1">
            <material>Gazebo/Red</material>
        </gazebo>
        <gazebo reference="${direction}_${order}_joint_1">
        </gazebo>
        <gazebo reference="${direction}_${order}_joint_2">
        </gazebo>
        <gazebo reference="${direction}_${order}_joint_piece_2">
        </gazebo>
        <gazebo reference="${direction}_${order}_cyc_1">
        </gazebo>
        <gazebo reference="${direction}_${order}_joint_3">
        </gazebo>
        <gazebo reference="${direction}_${order}_joint_piece_3">
        </gazebo>
        <gazebo reference="${direction}_${order}_cyc_2">
        </gazebo>
        <gazebo reference="screw_${direction}_${order}_1"></gazebo>
        <gazebo reference="screw_${direction}_${order}_2"></gazebo>
        <gazebo reference="screw_${direction}_${order}_3"></gazebo>
        <gazebo reference="screw_${direction}_${order}_4"></gazebo>
        <gazebo reference="screw_${direction}_${order}_5"></gazebo>
        <xacro:transmission_block joint_name="screw_${direction}_${order}_2_to_${direction}_${order}_joint_1"/>
        <xacro:transmission_block joint_name="${direction}_${order}_joint_2_to_screw_${direction}_${order}_4"/>
        <xacro:transmission_block joint_name="${direction}_${order}_joint_3_to_screw_${direction}_${order}_5"/>
    </xacro:macro>
    <!-- base_link -->
    <link name="base_link">
        <visual>
        </visual>
        <collision>
        </collision>
        <xacro:inertial_matrix mass="6"/>
    </link>
    <!-- LEGS -->
    <xacro:leg direction="right" order="first" />
    <gazebo reference="base_link">
        <material>Gazebo/Green</material>
    </gazebo>
    <gazebo>
        </plugin>
    </gazebo>
</robot>
[EDIT-3]-----
The tf trees I obtained when running robot_description files in the Gazebo and RVIZ environment are as follows. When you run it in Gazebo environment, the tf tree structure is broken.enter image description here
[EDIT-4]-----
I'm still trying to fix the error and I still can't see where I made a mistake. In the xacro file;
</joint>
When you change it like this:
<joint name="screw_${direction}_${order}_2_to_${direction}_${order}_joint_1" type="fixed">
</joint>
I noticed that my entire robot is in the Gazebo environment, but the same error (This robot has a joint named "screw_right_first_2_to_right_first_joint_1" which is not in the gazebo model) still persists.
I changed the joint type from revolute to fixed.
13
    $\begingroup$ read the error messsge and then read the xacro file ... the two are not the same $\endgroup$
    – jsotola
    Apr 2 at 23:48
  • $\begingroup$ better still do a search for screw_right_second_2_to_right_second_joint_1 on this webpage $\endgroup$
    – jsotola
    Apr 2 at 23:50
  • $\begingroup$ Even though I read the xacro file many times, I could not catch the error specifically. I have searched this web page many times. Although I found similar errors and examined them, unfortunately I did not correct them. $\endgroup$
    – furkan
    Apr 3 at 5:15
  • $\begingroup$ no, you are not understanding... I did not say this website ... I said this webpage that you are looking at right now as you read this comment $\endgroup$
    – jsotola
    Apr 3 at 5:30
  • $\begingroup$ you will find that there is no screw_right_second_2_to_right_second_joint_1 in the xacto file you presented $\endgroup$
    – jsotola
    Apr 3 at 5:58
Finally I managed to solve the problem. In other projects, I get the correct output without adding inertial matrix to empty links. Even though I couldn't understand it, I solved the problem by adding inertial matrix as follows.
Old
</link>
New
</link>
