I installed Ubuntu 22.04 on a rpi4(2gb) from Raspberry Pi's images. I have installed libcamera from Raspberry Pi github and built rpicam-apps from source.
Now, my problem is how to know if it has worked. My main pc still runs Ubuntu 20.04/Noetic, so it can't talk to Humble on the rpi4. What is the simplest way to see if ROS2 can send video to a topic?
I found a solution:
Install camera_ros from https://github.com/christianrauch/camera_ros/tree/main
Run the node:
ros2 run camera_ros camera_node --ros-args -p width:=640 -p height:=480
Use topic to check that video is being published:
ros2 topic hz /camera/image_raw
This is a round about route to showing the camera is working, but the usual tools like guvcview don't seem to work with libcamera, and the rpicam tools don't either.
