I've been trying to convert a rosbag which i've generated after running the kiss-icp algorithm (so output is sensor_msg/msg/PointCloud2) into a 3D map of the environment, by converting it into a .pcd format using the humble-pcl-ros library. For some reason it recognises other .cpp files as executables in the pcl_ros library (filter_cropbox_node, pcd_to_pointlcloud etc.) but not bag_to_pcd, leading to:
ros2 run pcl_ros bag_to_pcd.cpp /data/myrosbag.db3 /kiss/local_map /data/map1
No executable found
Is there any way to fix this or is there perhaps an easier method or package to use to convert my rosbag.db3 file into a 3D map? Thanks.
It is expecting the name of the executable, not the source file cpp:
Try:
ros2 run pcl_ros bag_to_pcd /data/myrosbag.db3 /kiss/local_map /data/map1
You need to include your node bag_to_pcd node in the build and installation process, in other words, add the node to the CMakeLists.txt file of the package to ensure it gets compiled and linked properly.
  • $\begingroup$ Made the edit in the CMakeList.txt file but now the build for pcl_ros is failing in the '#include <rosbag/bag.h>' line in bag_to_pcd.cpp, probably because i'm missing the package (rosbag is deprecated, think rosbag2 is now the one that is used). I've managed to convert my .db3 into a bunch of .pcds using this library link instead, but thanks for the help anyways, learnt a bit more about how the build process works. $\endgroup$ Commented Mar 25 at 13:36
