What is the clear difference between /reset_simulation and /reset_world. I initially was using /reset_simulation to reset the state of my environment periodically (in the context of RL).
This worked well until I added the functionality of deleting and spawning a new goal model when. From my observation the physical location of the model seems to "glitch". I understand that it has something to do with my condition to when I respawn (/delete_entity , /spawn_entity) the model. But it is clear that I am misunderstanding the process of /reset_simulation.
Often the model is just is not present in the gazebo world when it should be. I guess this could be /reset_simulation resetting the state of gazebo to when the model was not spawned.
I then looked into /reset_world which I believe is the better use case. But it doesn't work well with the slam_toolbox which is a crucial component of my package. The slam_toolbox complains about out of data TF frames (or something to that effect).
So to summarise I'm looking for clarification on the two services. The /reset ... service that I'm looking for is more to reset the robots to their original position in the world.
Currently using ROS2 Humble
This seems to be a duplicate of difference between reset_simulation and reset_world, which has (apparently) been migrated here, but I can not locate it1.
The answer to that question states:
These services correspond to the options under Edit in the GUI:
  • /gazebo/reset_world <-> Edit > Reset Model Poses
  • /gazebo/reset_simulation <-> Edit > Reset World
From the linked Beginner: GUI - User interface, under the section The Menu, there is a little more information:
Menu options
In text form:
  • Reset Model Poses (Reset models to original poses; do not reset time)
  • Reset world (Reset everything in world; reset time)
So, the resetting of the time seems to be the major difference.
1 See meta question, Has answers.gazebosim.org also been migrated to here?
    $\begingroup$ What confused me about /reset_simulation was that If I spawned a model in and then despawned it, subsequent calls to /reset_simulation, would undo the changes either causing the model to despawn when I want to spawned or spawn it when I want it despawned. /reset_world is the correct use case I found but it breaks most ROS2 packages, so I opted for /set_entity_state. Thanks for your answer $\endgroup$
    – nohacks
    Mar 23 at 11:40
