I installed all packages I need and write my controll.xacro file and my_controller.yaml file and write launch file correctly and in my source file I clone serial package.
However, when I clone diffdrive_arduino package but with foxy branch so I cannot colcon build it.
If i colcon build
In file included from /home/omar/project_ws/src/ros2_control_diff_drive/diffdrive/src/diffdrive_arduino.cpp:1:
/home/omar/project_ws/src/ros2_control_diff_drive/diffdrive/include/diffdrive_arduino/diffdrive_arduino.h:7:10: fatal error: hardware_interface/base_interface.hpp: No such file or directory
    7 | #include "hardware_interface/base_interface.hpp"
compilation terminated.
gmake[2]: *** [CMakeFiles/diffdrive_arduino.dir/build.make:76: CMakeFiles/diffdrive_arduino.dir/src/diffdrive_arduino.cpp.o] Error 1
gmake[2]: *** Waiting for unfinished jobs....
gmake[1]: *** [CMakeFiles/Makefile2:113: CMakeFiles/diffdrive_arduino.dir/all] Error 2
gmake: *** [Makefile:146: all] Error 2
This error appears.
If I do not build it, I launch my launch file the next error will appear
[ERROR] [ros2_control_node-2]: process has died [pid 10267, exit code -2, cmd '/opt/ros/humble/lib/controller_manager/ros2_control_node --ros-args --params-file /tmp/launch_params_o5gavlx1 --params-file /home/omar/project_ws/install/diff_bot/share/diff_bot/config/diff_drive_controller.yaml'].
[INFO] [robot_state_publisher-1]: process has finished cleanly [pid 10255]
Welcome at RSE. It is not possible to know what could be the problem if you don't add your code (package.xml, CMakeLists.txt, etc). Could you provide a public repository?
I'd suggest that you start with the official demos to learn how to setup ros2_control.
maybe you are missing a Package try this:
sudo apt install ros-humble-hardware-interface
