I have the following file /home/pi/mavproxy.sh which forwards the flight controller telemetry data using mavproxy to GCS(Ground Control Station)
#!/bin/bash
mavproxy.py --master=/home/pi/ttyUSB0 --baudrate 57600 --out=udp:192.168.10.12:14550
to automate this I write a linux services mavproxy.services
[Unit]
Description=Mavproxy service
After=network.target
[Service]
Type=simple
ExecStart=/home/pi/mavproxy.sh
Restart=on-failure
[Install]
WantedBy=multi-user.target
Now the problem is when I execute ./mavproxy.sh it work fine and forward telemetry data but when I reboot and do mavproxy.service Failed.
following is output of journalctl -u mavproxy.service which says KeyError: 'LOCALAPPDATA'
Mar 17 12:15:16 ubuntu mavproxy.sh[1076]:   File "/usr/local/bin/mavproxy.py", line 1489, in <module>
Mar 17 12:15:16 ubuntu mavproxy.sh[1076]:     start_script = mp_util.dot_mavproxy("mavinit.scr")
Mar 17 12:15:16 ubuntu mavproxy.sh[1076]:   File "/usr/local/lib/python3.8/dist-packages/MAVProxy/modules/lib/mp_util.py", line 285, in dot_mavproxy
Mar 17 12:15:16 ubuntu mavproxy.sh[1076]:     dir = os.path.join(os.environ['LOCALAPPDATA'], '.mavproxy')
Mar 17 12:15:16 ubuntu mavproxy.sh[1076]:   File "/usr/lib/python3.8/os.py", line 675, in __getitem__
Mar 17 12:15:16 ubuntu mavproxy.sh[1076]:     raise KeyError(key) from None
Mar 17 12:15:16 ubuntu mavproxy.sh[1076]: KeyError: 'LOCALAPPDATA'
